Nice. How's the turning with the 245s? You are brave on the 25 rear. I'm thinking I'll do 265/30 next year. Should be no poke no stretch. Loving the brake work.
No problem with the 245s works perfectly. on the rears I usually go with 275 /30 but the tire I went with made their sizes over sized and it's close to a 275/30 which works out well. I looked at 265 30 but can only find them in high dollar tires. But I had minor rubbing issues with275 on the rear. It was rubbing on the face of the rim not the tire at all. So a 275/30 should work fine with no problems
Same issue I had in the rear. Did a slight shave on the inside fender and problem solved. It was only rubbing on one spot on the inside probably due to alignment issues. I still need an alignment but having trouble finding a place who doesn't clamp the wheel
