DIY Front brake pads F Sport
Old 01-21-16, 11:05 AM
pqn628
pqn628's Avatar
Originally Posted by jduong29
I just got my front brakes replace on my GS350 F Sport. I notice that my rotors has a lip at the end and after the shop resurface my rotors the lip was gone. I didn't want to spent an extra $600 for the pair of front rotors and I wanted my rotors to be resurface. Is this normal to have a lip or not?
600 for rotors? Are you doing the work or is a shop?
when I had my 07 GS, I used Centric Rotors with Akebono pads. . I believe Centric manufacture rotors for Lexus. They only different between buying it at Lexus and buying it online is the one online has a protection sealant around the inner ring of the rotor (usually black). Akebono pads were great. If you go to the third gen GS threads, you can read more about these two brands.
The two links below are for the 2015 GS base model. I can't find any for the F sport yet. Hopefully they will have them by the time I need it.
Centric Rotor Centric Rotor
Akebono Pads Akebono Pads
Old 01-21-16, 11:51 AM
DVADER
DVADER's Avatar
Thank you for creating this thread! You just saved me a few hundred bucks! Next time you're in NY I owe you a beer.
Old 01-21-16, 12:19 PM
joedaddy1
joedaddy1's Avatar
how many miles before a pad change on your cars?
Old 01-21-16, 01:43 PM
Davenlei
Davenlei's Avatar
When I bought my 2013 CPO F-Sport, they had to put new pads/rotors on. The car had 18K miles on it and the front pads only had 10% life left on them.
Old 01-21-16, 02:01 PM
jduong29
jduong29's Avatar
Centric Rotor
Akebono Pads
I had a private local mechanic shop do the work for me. I only paid for labor. I order the OEM brakes online for $75 and have the mechanic installed them for me. I was told by the Lexus stealership that I needed to replace my brakes and rotors but I decided to only replace my brakes. Each rotor cost $279. If I was to buy a pair its almost $600 extra. I was told GS F Sport front brakes and rotors cost more because its bigger than the normal one.
Old 01-22-16, 06:12 AM
pqn628
pqn628's Avatar
Check out RockAuto. Below is the link to the 2015 GS350 Rotors
Rotor
Admins...can you add this to the DIY sticky?
Old 01-23-16, 04:22 AM
jduong29
jduong29's Avatar
Rotor
I am talking about OEM rotors for that price. I know that aftermarket rotors are cheaper but I don't want to take a chance putting nothing but OEM parts on my car. Thanks for your info tho.
Old 01-23-16, 06:29 AM
Davenlei
Davenlei's Avatar
Rotor
I don't see front F-sport rotors (14")
Old 01-23-16, 06:33 PM
sonyfan
sonyfan's Avatar
This thread should answer your question
https://www.clublexus.com/forums/gs-...rt-brakes.html
Old 05-20-16, 02:01 PM
Emotionr
Emotionr's Avatar
I would not recommend Ceramic, for the following reasons:
  • Do not produce as much cold bite as semi-metallic pads – may not be ideal in extremely cold climates
  • Do not absorb heat as well as semi-metallic pads which can increase brake system temperatures
  • Good all-around braking characteristics but were never designed as heavy duty/racing brake pads
If you had a Honda Civic or a car that is lighter in weight, then it be great! If you do not have the F-sport version or do not care too much about braking power (i.g. heavy braking/racing), then ceramic could be fine, but is not recommended due to the weight and the point of F-Sport suspension (Lexus design recommendation).
If you care more about the brake dust then ok, but if you want more braking power, it is recommended to use semi-metallic or the organic.
OE is organic ones... but wears fast.
Semi-metallic would be the most versatile as Semi-metallic will provide the best over Organic and Semi-metallic:
  • Dramatically increased braking performance over organic pads
  • Have a much higher thermal threshold due to metallic content
  • Still provide good cold bite
  • Have a much wider operating range (temperature)
  • Low compressibility – will provide a firmer brake pedal feel
  • Much more resistant to brake fade than organic pads
  • Numerous compounds available – suitable for anything from daily street driving to extreme track use
If you are just concerned mainly due to noise... there are many semi-metallic that are minimal in noise. However, it is more about the install of the shims, grease, and rotors at this point.
I.g. Wagner Thermoquiet, and use the grease vicariously
Old 05-20-16, 10:54 PM
trbosmitty
trbosmitty's Avatar
Akebono pads are very good pads!
I just resurfaced my front rotors this week and the rotors where not budging from the wheel bearing. I had to use this method to pop them off.
With the caliper removed, you should be able to pull the rotor off. If it's stuck, you'll need at least one M8-1.25 bolt. On the rotor you'll see two threaded holes close to the center hub on either side of it. It is recommended to fit the bolt into the hole to make sure it threads properly, as the threading and size may slightly vary with the brand of rotor. Slowly thread the bolt into the hole; if you only have one, you'll need to alternate the sides to do it evenly. Eventually, the rotor will pop free and you'll be able to remove it.
Spideyman1 (01-13-17)
Old 05-21-16, 08:23 AM
F-LEX350
F-LEX350's Avatar
thanks for posting. Where did you position the jack?
Originally Posted by mattah
I know there is a good write up already done on the IS350, but thought I might as well snap some pics when I do mine.
WHAT YOU NEED
-Brake pads
-C clamp
-Brake cleaner
-Pliers
Install time 45-60mins
Take wheel off
Ta-Dah!
Remove clip, then remove pin. Helps if you push down on the metal plate
Take c clamp to push together front and rear pads
Pads removed. Take this time to clean shims, clip and pin
Installed, reverse process and you did it
Super easy, I don't even change my own oil and felt this was a sinch. Saves you money, take for instance local Lexus dealer wanted close to 400.
I used Akebono ACT1118, highly recommend them. Better than Oem, no noise. Amazon.com: Akebono ACT1118 ProACT Ultra-Premium Ceramic Brake Pad Set: Automotive
Old 05-21-16, 07:45 PM
SneakySt3v
SneakySt3v's Avatar
Just changed my pads today with Akebonos. It was super easy, thanks for the post.
Old 09-06-16, 04:12 PM
LatinLS430
LatinLS430's Avatar
Very good DIY!
Old 09-12-16, 07:10 PM
IndaC
IndaC's Avatar
Default Thanks
HA!!!!!
Crown Lexus - $399 brake special..?
EBC Yellowstuff $120.
better than oem.
My cousin works for Lexus corp. And according to him. No need to turn rotors, if you haven't started grinding...
$200 to spend anyway I want.
Thanks for the detailed write up
Quick Reply: DIY Front brake pads F Sport
