DIY Front brake pads F Sport
#31
+1. No need to turn unless you warped them, ie vibrating when braking from high speed, or the pad sensor has not touched yet.
#32
Thanks for the post, the simplicity of your explanation gave me the confidence to do this myself. I wasn't sure where to apply the brake grease so I put it on the backs of the shims, no problems when I took the car out for a test drive.
Today I wash the car and hope I see much less brake dust this week. Are one brakes were slightly less grabby than the OEMs which is better IMHO.
#34
Hey guys, have a 2015 fsport gs350 and just changed the front breaks to the akebono proact pads, I installed them and there is a squeal at low speeds and light breaking. Any tips on how to get rid of it?
#35
did you put the grease on? Also you will need to resurface the disc if it is still within the spec.
#36
i did put grease, but it didnt come with a lot, dont know if i put enough, Also, i have read 2 different methods, one that says put it on the back on top of the shims and one that said put it in between the shim and the pad. I did not resurface rotor
#39
I used this to quiet my front left squeal.
https://www.amazon.com/CRC-Disc-Brak.../dp/B000CINV88
I have Centric PositQuiet pads.
#40
Ok i used the crc stuff and it worked, for about 3 days then the squeal came back. took the car to a shop who said that the rotors need to be replaced, they dont reccomend resurfacing. Only rotors I can find that are 14in are the oem and the ebc RK7636X, it shows the ebc ones are 1-piece though, will these work? any other remedies to get the squeal to stop
#41
Autoanything shows that it'll fit:
http://www.autoanything.com/brakes/7...5A4454921.aspx
#42
I'm on my 3rd set of pads on my 16'.. 10k miles.. latest pads(3k miles on them) is the akebono proact pads, after 3 months the squeal is back.. i think the issue is the glaze on the rotors, in the past id just slap the pads on and let it be.. plenty of lub was used. My solution is to sand the rotors and pads to get the glaze off and see if this work.
#43
the rotors are listed on ebc catalog and say they are 14" and fit the gs350 fsport rwd. i ordered them and will see if it works, hopefully they do because the oem ones are too expensive. even if they are one piece and they are made correctly they should still fit right?
#44
