DIY Front brake pads F Sport
#46
Just got them, here are the pics of the them pre install. They are black which I didnt know they were going to be. I just put the akebonos on last week, do i need to switch them out or can i sand them and rough them up a little bit?
#47
They're supposed to be black. That coating will wear off once you brake pads touch the rotors. Put a side by side pic of the Original 2pc rotor and the EBC rotor before you install them I just want to see the comparison. Good Luck with your Install.
Bartman619 (12-16-16)
#50
#52
ok, so I tried installing the new rotors and figured out they sent me the wrong ones, I wish I checked the size prior to removing everything. Will contact them and see if this is indeed a mistake or if they dont actually have the correct size.
#56
Just got a response from the vendor. they said that indeed I did receive the wrong part even though the box was marked with the right part number. they are sending me a pair of the correct size. I will update once received.
#58
Just got an email saying that they will ship on the 7th of January. Not sure why it takes so long to ship replacements but we will see what happens when they get here
#59
Wow! Those are an interesting looking braking rotor with the black coating. Must be for corrosion resistance?
