Safe to use Staggered wheels on AWD?? Need the facts!
I am looking to buy a set of used f sport wheels on ebay and every complete set I have seen are all staggered.
Also for those who say that staggered wheels need two different tire sizes, it depends how much wider the rear wheels are.. the tires I want can accommodate width of 8 to 9.5 inches with the same size tire. The f sport wheels are 8" wide in front and 9" wide in back. So same tire size on all 4 is fine right?
But does having 2 different rim widths do anything negative to the AWD system? I assume the wider rims are slightly heavy and I have no clue what affects AWD, if the different weights will mess it up or what not.. i dont know..
exclusive matchup
if you have directional tires, then you can flip the tires so the outside becomes inside, that could be quite beneficial given that most cars have negative camber these days.
yes you can flip the tires, i do that all the time. but you can do that on staggered setup too as long as you get the right tires (directional).
"can" doesn't mean it's optimal. if you do the same tires front and rear it is going to look funny. on the front the tires will appear to be quite meaty, but for the rear it will look stretched. not a good idea
if the tires are not directional, then all you can do is just to put flip the wheels (not tires). if the alignment of the car is right, left and right wear on the tires should be very similar. so doing this kind of rotation won't gain you anything.
exclusive matchup
if tires are directional, they can only go in one direction. if the tire is mounted on the right side, that means the "left" side of that tire will wear out faster due to negative camber. so what people do is they flip the tires, meaning the right tire goes to the left, and left tire goes to the right. so now on the same originally right tire that's worn on the "left" side, now it's on the left side of the car and the "right" side of the tire wears more, thus canceling out the uneven wear.
for non-directional tires, there is only outside and inside. no matter how you put it, outside is still outside. inside will always wear faster.
that's big reason why i always get directional tires
I would seriously consider if your running a staggered set up that you keep the diameter equal and the rolling diameter as equal as possible.
I'm now experiencing differential problems and it all points to the staggered wheels being the cause.
Problem is it takes awhile and the problem is it appears some people get away with it. Hard for me to nail down. The other issue which I debate is, according to my research you actually negate performance on the Lexus, other brands, not sure, they have more advanced AWD or they are designed still applying higher % traction to the rear.. Yes the 2015 lexus does have staggered wheels and the rotational diameter is only off .56% or so.
Possibility causing less steering performance as well. Additionally I believe you may lose braking performance due to the leverage the wheels impose on the factory braking system.
