Radio issue
Have a 2013 GS450h. When turning a sharp corner, the radio sometimes changes stations or if it is not on - the radio turns on. Anyone else have this issue or know the cause? thx
Hi lamberg, I also have a 2013 GS450h as well (U.S. version) and mine does not experience that symptom. You might want to have a dealer check that out for you if you're able to replicate it easily.
This is also the first time I'm reading of such an issue as well.
Hope this helps,
~ Im2bz2p345
Hope this helps,
~ Im2bz2p345
I'd get it back to the dealer while on warranty as it's usually quite costly to find ground issue's. With any luck it will be something they have seen before and can fix it easily.
