Preferred Synthetic Oil Choice?
Old 03-30-17, 04:35 PM
  #46
bclexus
bclexus's Avatar
Received 2,176 Likes on 1,559 Posts
Originally Posted by bclexus
0W-30 and 5W-30 has the same viscosity at normal full operating temperature of 100°C (212°F). The last number is the viscosity at 100°C. For example, 0W-30, 5W-30 10W-30 all have the same viscosity at normal operating temperature.
The first number (0W, 5W, 10W, etc.) is the viscosity at the cold temperature specified. A 0W oil will provide quicker lubrication to bearings on cold starts (compared to 5W, 10W, etc.), which is when an engine's bearings are most likely to be damaged due to dry metal-on-metal contact due to [cold start] oil starvation.
Car makers moved to 20 weight viscosity engine oil for better fuel mileage. Some adjusted the bear clearances a bit, some didn't. The 20 weight viscosity engine oil provides more than ample lubrication for a long engine life. The move to 0W engine oils do more to prolong engine life because it reduces wear where the wear is most prevalent - cold starts.
Originally Posted by Byprodrive
Depends upon the climate where you operate your vehicle. Drink the Kool-aid if you wish.
Wrong again.
What I stated is fact...and has nothing to do with the climate in which you operate your vehicle.
Old 04-02-17, 11:48 AM
  #47
Byprodrive
Byprodrive's Avatar
Wrong again.
Wrong again, operating temp is the main factor.
Old 04-02-17, 12:56 PM
  #48
RA051823
RA051823's Avatar
Originally Posted by vinnier6
My buddies 2015 Lamborghini calls for like 15k mile intervals
I bet your buddies Lambo is every 15k or one year which ever is first. Lamborghini knows it takes the majority of their owners 4 years before their car will see 15k on the odometer. When I had my Aston Martin DB9 the oil change interval was 1 year or 10k miles which ever was first. I remember their was a guy in the club who thought their was no tie limit. It took him almost 6 years to put 15 miles on his car but by that time the oil was muddy and sludgy and he lost the lower end. Aston Martin wanted 75k for a new engine. I'm the believer that oil is the life blood of the engine and changing it often is cheap insurance for longevity. Personally we change our oil every 7k miles or 1 year which ever is first in our GS350. I use Mobil, Valvoline, or Castrol... it really depends on what happens to be on sale at that time.
Old 04-02-17, 01:23 PM
  #49
bclexus
bclexus's Avatar
It's very clear you don't have a clue what you're talking about.
The second number after the 'W' indicates the oil’s SAE viscosity measured at 212° F (100° C). It is always measured at this temperature...
The 'operating temperature' of an engine is typically 200° to 212°F (100°C), regardless of what the ambient temperature may be.
Old 04-03-17, 01:37 PM
  #50
itjustme
itjustme's Avatar
so I got my GS350 about a month ago at 34k miles. It hit 35k miles and the maintenance light came on... I figured it's just based on the mileage and doesn't need an oil change. After getting to 35,700 miles it's started giving me a warning saying I need an oil change. The car was a pre owned from a Toyota dealer and was a previous lease vehicle which should have been fully maintained by the Lexus dealer. Based on what I read for the maintenance schedule, I shouldn't need an actual oil change until 40K miles, right? Or should I just take it in to Lexus and have them do it?
Old 04-03-17, 02:10 PM
  #51
RA051823
RA051823's Avatar
Did you check the maintenance app on the infotainment system? It will tell you what is due. The maintenance light should come on every 5k miles if defaults are still programmed.
Old 04-04-17, 09:10 AM
  #52
itjustme
itjustme's Avatar
No I didn't know there was a maintenance app in the infotainment system.. Will check it. But when the car turns on it now shows the previous dealership it used to be serviced at and shows that it needs an oil / filter change - wasn't sure before if it's accurate or just a generic maintenance thing.. Guess I have my answer now :-)
Old 04-04-17, 10:47 AM
  #53
bclexus
bclexus's Avatar
You should Register your car on the Lexus Owners Site which will give you the [Lexus] maintenance history of your car.
Also, as you have learned - you should configure the Maintenance App to your liking. I think most people do not use the Maintenance App, but instead us the simple instrument cluster maintenance reminder feature that alerts you every 5k miles.
itjustme (04-07-17)
Old 04-05-17, 05:39 PM
  #54
Byprodrive
Byprodrive's Avatar
[QUOTE=bclexus;9822384]It's very clear you don't have a clue what you're talking about.
If only you had adequate reading comprehension you might be able to understand !
Old 04-05-17, 05:47 PM
  #55
bclexus
bclexus's Avatar
Once again, it's very clear you don't have a clue what you're talking about...
Old 04-07-17, 11:12 AM
  #56
itjustme
itjustme's Avatar
Anyone have experience going to Davenport Motors here in Dallas instead of Lexus dealer? What's your experience been like? Recommend it?
Old 08-14-17, 01:17 PM
  #57
mopudding
mopudding's Avatar
Does the elapsed time (months) between changes, within reason, really matter? I tend to follow the mileage driven. What happens to synthetic over time?
Old 08-14-17, 03:58 PM
  #58
bclexus
bclexus's Avatar
If synthetic engine oil was used in an engine that ran at a constant 2,000 RPM that engine oil would probably test out to still be perfectly reliable for engine protection after 100,000 miles, but of course that's not the norm. It is required that the engine oil and filter be changed at least once a year, regardless of minimal mileage. The reason for the once-a-year requirement is because engine oil can become contaminated with fuel, combustion by-products and moisture over-time...especially so if the vehicle is driven short distances and not given the chance to get up to normal operating temperature, especially during cooler months.
mopudding (08-14-17)
Old 08-15-17, 09:41 AM
  #59
kingofire
kingofire's Avatar
I am a Royal Purple *****.....My 2017 GS is getting fed Royal Purple HPS 5w20 after the free oil change at 10,000 miles(currently at 6500 miles).....yes I know Toyota recommends 0w20 but Royal Purple HPS doesn't come in 0w20.
Old 08-15-17, 09:58 AM
  #60
vuong05
vuong05's Avatar
Mobil 1 here.
Quick Reply: Preferred Synthetic Oil Choice?
