Aftermarket Wheels and Alignment
#47
From my experience, this car is really tough to align, u need to find a shop that has a good equipment and a guy that knows how to fix pulling cars. I had the same pulling problem and my steering wheel was crooked. I did 3 alignments, 2 at an independent shop and 1 at the dealer and they couldn't fix it 100%, the car was still pulling to the right. That's $200 down the drain for nothing but good thing the dealer one was free.
Then I found another local shop in Burbank through Yelp and he only charge $65 and this guy was able to fix the pulling problem and center my steering wheel!! Car is dead straight now at any speed and everything is within specs too. He must have a really good alignment machine and knows what he's doing. I had been counter steering for over a year and man it feels really good when u let go of the wheel and the car rolls straight.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
37 PSI front and 38 PSI rear cold. They go up to 40/41 under normal rolling temp.
#48
#49
You're on 20" not lowered right? So are your wheels slightly butterflied (neg camber) in the rear after the new wheels? Did the alignment fix this? I recent got 20" without a drop and as soon as they dropped the car, I noticed the rear tire tilting a few degree inwards. Drives straight and all but will wear down the tires a lot faster.
#50
Yup on 20x9's not lowered. Mine butterfly out a bit in the rear.I opted for a squared set up so I can rotate my tires. Had my tires rotated last week and the Discount tire tech said they are wearing evenly but thats not the case. Now that the rears are on the front my car vibrates and drives pretty rough plus it makes a howling sound that wasn't there before. I took it back in and had them rebalance my tires and even then the issues are still there. I think I need to get a camber kit for the rear. I feel whats causing the rough ride and noise is the fact that the inner part of the tire is worn slightly more then the outer part. Now that those tires are on the front and straight the uneven wear is causing the problems im facing. I bought the lifetime alignment from Brake Check so im going to go and take it in to see if i need an alignment. They had suggested I buy a camber kit the first time I took it in but I didn't listen.
#51
I'm facing the same issue. My setup is 20x9 front and 20x10 rears. My rear is slightly butterfly prob 2-3 degrees. So i'm guessing our cars do this even without lowering. I want to lower but is afraid it will be even worse. The camber kit will only dial it as far as 3 degrees so after lowering, I'll still have a slight tilt.
mexguy89
03-18-13 07:29 AM
phenomeno
07-02-12 10:08 PM
Anthracite SC
Wheels, Tires & Brakes Forum
10-29-03 10:49 PM
