Battery on key replaced, but doors won't lock?
After weeks of receiving an alert about my battery being low on my key fob I finally replaced the battery. But the drivers side door won't lock. The car does start, and even after you put it in reverse the doors still won't lock. Can someone please provide an explanation and an easy fix please? ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Thank you.
Thank you.
Do u have the spare key inside the car? The car won't lock if the spare key is detected inside the car.
The door lock by shifter feature can be changed in the nav settings I believe, or from the ECU with an OBD2 app. U can also set it to auto lock by speed.
No the spare key is not inside the car. And yes I have seen these settings but no they are all normal. When I try to lock my car usually the headlights would blink and the doors would lock and now its not doing any of these.
