nitrogen or regular air for my tires?
Robertcave (07-05-21)
For those contemplating and/or maintaining nitrogen in tires, you may wish to consider the following information found within Lexus Tech Tip L-TT-0068-11 [2013-07-02]: "Best Practice For Tire Rotation & Nitrogen Filling Procedures."
Regarding nitrogen filling, it states "Some customers may complain about vehicle vibration due to incorrect tire balance following a nitrogen refill. It has been found that nitrogen replacement may cause tire out-of-balance conditions if the tire is deflated and refilled with weight on the tire. When the original air in a tire is evacuated during the replacement procedure, the internal pressure against the tire carcass is reduced. If the vehicle is on-the-ground during this procedure, the low tire inflation pressures may cause the tire sidewall to compress. When performing nitrogen replacement procedure with the tire/wheel on the vehicle, ensure the vehicle is lifted on a rack or jack stands. This prevents the weight of the vehicle from compressing the tire sidewall when tire pressure is reduced. Alternatively, the nitrogen replacement procedure may also be performed with the wheel/tire removed from the vehicle and suspended off-the-ground; for example, on a wheel/tire balancer machine."
Hot = Increase in Tire Pressure
Cold = Decrease in Tire Pressure
Make a habit of Checking every month just to make sure , your getting the right amount of Handling from your GS with the Correct Tire Pressure.
