Is the first oil change really at 5000 miles?
I have a 2015 GS with a little over 1000 miles. I've never had a new car that waited until 5000 miles for the first oil change. Is it really good for the engine to go through the first 5000 mile break in without an oil change?
Doug
Doug
First oil change is at 10k miles, which is very soon considering that Porsches get oil changes every 20k and BMWs get oil changes every 15k
I do it at every 5,000 miles on both of my GS's, it's added peace of mind. We had an adviser from a local independent repair shop that got BMW's that followed the 15k recommended oil changes. When they pulled the valve covers, you would see the damage that 15k and beyond oil changes do to a car, with higher miles.
Regarding the first oil change, many people believe the factory fill has special additives to help the engine break in (I can't comment one way or the other). I've learned from my Viper to change it after 500 miles, that way no remnants from assembly stay in the system much longer than needed. Quite a few owners had motors that grenaded with less than 5k miles. Either assembly lube or metal shavings that ended up destroying the motor. Friends in the performance world will assemble built motors, and after the first start and idle, they do an oil change immediately. It's cheap insurance for a lifetime of fun.
Truth be known, the engine oil and filter could easily go 30,000 miles of normal driving conditions and still test perfectly good for another 10,000 miles.
The 'old school' method of changing the engine oil and filter after just 500 or 1,000 miles in a new car to get rid of metal particles in a new engine is simply not necessary with today's engines. And, changing today's engine oil and filter every 5,000 miles is like changing your air filter every 6 months, or like using fuel injector cleaner every third fuel fill-up. The SN engine oils and new car engine building practices are far different from the old oils and practices used decades ago. But, if it gives you piece of mind - then by all means do it...change it every day.
isnt that dependant on different driving condition also. severe condition or normal? mine usually short trip. each way is less than 10 miles and stop/go city driving with alot of traffic like. the temperature here is like 29 to 34C all year round. I do EO change every 5k miles.
An oil change for a Bugatti Veyron costs over $20,000!
