CarID is telling me that 245/35/20 tire size will not fit, will hit fenders.. true???
@Kane007 a 245/40 tire on a 19" wheel will fit the GS without an issue. This question comes up quite a bit on the forum but obviously folks aren't typically keeping up with the myriad of threads that are started with similar questions - definitely search the forum for answers. I even saw your post from a few year back which no one answered (https://www.clublexus.com/forums/gs-...ml#post9181453)
To save you time, many members here upsize from 235/40 tires to 245/40 tires simply because they can't get 4 tires in the 235 size in the same manufacturer. See this thread (posts #12 and #14) for members running Vertini and Niche wheels 19x8.5 all around on 245/40 tires:
https://www.clublexus.com/forums/gs-...l#post10002523
https://www.clublexus.com/forums/gs-...l#post10384505
Post some pics when you get your new wheels!
The following 2 users liked this post by PilotX:
OUT FOX EM (02-17-20),
signdetres (02-18-20)
I'm sorta in the same boat as Kane007. I recently bought a set of used Velgen VMB5 19s for my AWD GS 350 and was what tires I should run with 19x9 +35 ET Front and 19x10.5 +45 for the rears. I was eyeing the Continental DWS A/S tires as well. Thoughts?
The car is not lowered and I do not plan to lower it in the near future as well.
Everyone speaks highly of the Continentals and you absolutely can't go wrong if you get them on sale in the sizes you want: https://www.clublexus.com/forums/gs-...06-tested.html
Continental makes a great tire. Continential, Michelin and Pirelli are the most popular tires for the GS when folks replace from the OE Dunlop and Bridgestones.
If you like the comfort and ride quality of your car now, don't go to 19's stick with 18's. Also 19's are more prone to getting bent from potholes because there is less rubber on the tire to absorb the impact. You could also get a slightly lower offset from stock to get a more flush fit.
