HID bulb replacement for 2015 GS-F
Has anyone replaced/upgraded their stock HID bulb to the 6000K? If so, what bulb type and is it hard to do it yourself?
Thanks
Thanks
Go with Philips Ultinon D4S 6000k.
I bought one from NigelJDM $265 one bulb burnt in a year [no warranty replacement nothing waste of $265].
Bought another pair from a different seller on eBay for around $240 been running strong for 2 years now.
You need to locate the headlight bulb housing and twist it open there are 2 clips holding the bulb you need to release it and bulb comes right out I just had difficult putting the bulb back in correctly and then you need to put the housing back and turn clockwise to close the housing. Can help you out if your local. I changed mine on my 15 GS.
Wear latex gloves and hope your hands are not big or else will be very difficult and you will have few cuts on your hands.
Yeah if you have big hands, the driver side headlight is going to be a lot tougher to change. It's doable, but you're gonna end up with a few scratches. I ended up taking off the entire headlight unit to change.
