Foot well LED replacement
#61
By the way has anybody had any success in swapping out the rear footwell lights? Not that I have the front done, I am dying to do the back. It makes it so much easier to see in the floor boards. I have found the rear foot lights, but can not see any way to really access them to be able to put in a new light. They are so imbeded in the back of the seats.
#62
I got as far as almost removing the bottom portion of the cover on the back of the seat. But led was a bit higher than what it gave access to. Hard to explain. But i think its doable to swap the light
#64
Folks,
I am envious to have better lights in the footwell area. Unfortunately the amber LEDs (JDM ASTAR 4pcs Super Bright 5630 SMD 194 168 2825 W5W T10 LED) not currently available. Option-B?
Thank you
Thank you
#65
You can just go to any car LED lighting site and buy a different bulb from them. VLEDS.com has really good customer service and their products are usually higher quality than some of the others around. Just search up the size and options will pop up.
#66
Option B:
http://www.ebay.com/itm/131287457082?_trksid=p2057872.m2749.l2649&var=430575568559&ssPageName=STRK%3AMEBIDX%3AIT
