DIY: JDM Fog Light w/ OEM Switch
#31
So...something like this? http://www.ebay.com/itm/13-15-LEXUS-...JXeBoF&vxp=mtr
Mjn88, the ijdmtoy led fog light kit is a straight hard wire to the DRL lights, so they stay on all the time. The kit does not come with harness or switch to turn on/off if you are looking for that function. You could buy a generic harness and switch on eBay like others have on the site.
#33
Yes, the connector will still be the N28. Only difference is the added extra wiring for the on/off switch.
#34
#35
#36
#39
the stalk will have two extra pins. the n28 connector will be missing those wires. the two wires are to be plugged into the n28. one will become the ground and the other goes into the main computer.
Nigel-JDMParts (02-18-17)
#40
PK, i see you tapped the fuse box to power the fogs. Is there anywhere else in the engine bay where power could have been tapped? I'm trying to trace my fog light install as they are not getting any power. The indicator on the instrument panel illuminates though..
#41
How did you make it work?
I still haven't figured out the wiring yet on mine.
I want fog light indicator
https://www.clublexus.com/forums/gs-...tions-pic.html
#43
#44
All the pins are there for us to tap into but the wires aren't there. If you can take some pictures of your setup I might be able to help.
#45
