Car still pulling to the right
So I went to the mechanic today and had them uncounted the front and flip them, it still pulled to the right a little. I said fine I can't fix it. So I took off the vossens and put the stock wheels back on. The car drives straight down the road. I have given up on the wheels. I have no idea what it can be now. Also I have vossens for sale now if anyone would like them
Damn so it pulls to the right so you are getting rid of your wheels? thats tough. My car pulls a tiny bit to the right but theres no way Im getting rid of my wheels...I love them too much!
Did you try switching tires as others have suggested? I doubt its the rim itself. I know its a pain in the *** trying to figure out what the problem is, like going back and forth to the shop but once you fix you wont have to worry about it anymore.
Good luck
MEAHT
Good luck
MEAHT
Hey guys hope you can really help. My place did an alignment and got all the numbers back into the green.
What could be the problem that it is pulling to the right. Also the steering wheels turns a little the the right as well. The tire pressure is perfect and the tires I am running are nitto 555.
Azngster35-I don't understand that if the toe on the rear is off to the left, how it affects the car pulling to the right? If that fixes the problem, then the wheels will not be for sale.
It should fix it I hope. Because both of the rear wheel is slightly turn left according to your alignment sheets. The correct way is to have both of them toe inward to help it go straight. So as what I see is your right rear is correct but your left rear needed to be toe in and not out. Trust me go back to where you got it done and tell them that you got Lexus to look at the alignment sheet print out that the right rear need to be toe in. Try that and see. I know it will help I hope. I use to mess with alignment when my friends had a shop with the alignment machine.
Azngster35- I would like to thank you huge for the information of the alignment. It was exActly that. They fixed it and actually got the alignment even better then it was.
Glad I could help out buddy. I know it can be annoying when the car not driving straight. I guess the rim not for sale no more huh lol.....
Did you take it back to the same shop? What did they say about their first alignment (being in the green) needing to be changed in order to make the car drive straight?
