10mm spacers. What options do we have? H&R doesn't list them...
And I don't want Bolt on pressed in stud versions. I am going to do the Tanabe NF210 drop and I currently run the slightly wider 245 and 275 tires on my OEM F Sport wheels, so I am concerned the 15mm front and 20mm rear spacers may be too much which is why I was thinking 15mm rear and a 10mm front....
Thoughts?
Here is the smaller 235 and 265 tires on NF210s with 15mm front and 20mm rear
Thoughts?
http://www.evasivemotorsports.com/mm...=HR-DRS-SERIES
I believe these should work and they are from H&R.
DRS 15mm 30656014
DRS 20mm 40656014
DRM 25mm 5065601
Based on this, I would think the 10mm would be 20656014
Which fits the right specs:
https://www.stillen.com/h-r-toyota-m...-20656014.html
But when I call H&R they say something about the hubcentric lip on the hub doesnt work well with the 10mm which is why they dont use it....I guess I should just do the 15mm and hope it doesnt rub OR put the 15mm in the back and a 5mm up front to be safe.
