Brake dust?
#31
I used Akebono Performance Ceramic Pads on two Infiniti Sport Sedans and the dust is barely noticeable and the stopping power is same as OEM.
Will probably try them on the GS
#32
Many reasons..... Could be cost, supplier availability, or simply Toyota wanting to work with their established OEM supplier as oppose to some other aftermarket "performance" brand.
#34
Also, for whatever it's worth - BMW is well-known to have OE brake pads that produce huge amounts of brake dust. The same applies to BMW (as it does Toyota/Lexus) - BMW thinks their choice of brake pad is best [compared to low dust aftermarket pads]. And, don't think for a second that BMW doesn't [also like Toyota/Lexus] have the means to duplicate whatever low dust aftermarket brake pad that currently exists if they wish...
#35
What does best really mean? Isn't that subjective? Best could mean anything...... price, cost, availability, noise, life, reliability, dust.... etc.
Saying Toyota brake pads are Toyota's finest is like saying the Bridgestone tires they equipped with some cars are the best..... and we all know that is not true.
Same for the stock springs. Many have chose to "upgrade" their suspension by changing out the springs.... because the factory springs are not neccessarily the best... it's just the best compromise between comfort, cost, performance, and reliability in the eyes of Toyota.
It's a business decision that they use to include a certain brand of part on the car. Obviously, the part needs to meet their specs and the general framework of what the car is intended for. But that doesn't mean that they put the best of everything in the car...
As great as this car is ......The GS is not a "spare no expense" car. There are indeed compromises. Otherwise, they will have no room to make a profit!
#36
Same goes for springs - aftermarket springs may lower the body an inch or so which appease some owners with a smaller wheel gap, but that does not mean the aftermarket springs make the car handle any better. In most cases changing to aftermarket springs ends up damaging the chassis' dynamic loading, alignment and handling characteristics and makes for premature tire wear and eventual damage to struts. In other words, the Toyota/Lexus engineers know a bit more about what is best for a street driven vehicle.
#37
I think the OE GS brake pads stop very nicely, are quiet, and have very good bite when cold or at low speeds. I'll change to the Akebono Performance pads because they are more linear (less grabby) while being "less dusty."
Brake pad life and brake dust has a lot to do with the driver. My neighbor's GS eats thru pads every 15k while I still have about 40% at 30k miles.
On the other side of the spectrum, I changed out a '13 Camry's front pads at 30k miles and it still had 70%+ pad material remaining. Owner hated the lack of stopping power and dusty wheels. Loves the Akebono ProActs I put on![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
#38
The Toyota/Lexus engineers have chosen not to give choices when it comes to OE brake pads like they do with multiple choices for tires for the same vehicle. The car maker has decided through numerous, exhaustive tests over a prolonged period of time, what they think is best based on a wide assortment of criteria.
I’m with you on the stock pads being “the best” for me. But I would be totally ignorant for saying that they are the best brake pads, period. That would just be ludicrous. That’s very narrow minded thinking.
#39
Have you ever wondered why the brakes on BMW, Mercedes-Benz, Porsche, Audi, McLaren, Lamborghini, etc. produce a lot of dust? The answer is really very simple - because the brakes are made to stop better than a brake that doesn't produce a lot of dust. Less dust equals less stopping power. Many car enthusiasts accept brake dust on a performance car as a necessary evil, much like accepting not such good fuel mileage, a louder exhaust, a loping idle due to cam lobe separation, stiffer suspension, etc. from their performance car. Would you use low dust aftermarket brake pads on a name your performance car? I'll bet the answer would be 'no'! I assume you bought your Lexus GS 350 for both its looks and performance, among other things such as reliability. Then why would you use low dust aftermarket brake pads on your Lexus GS 350 luxury performance sedan?
#40
In the past, I've owned (2) BMW 7-series, (1) BMW 5-series (1) BMW 3-series, and the Acura NSX. I did indeed put aftermarket performance "low-dust" pads on all (5) of those cars..... and to me, they were much better pads than the factory (personal subjective opinion.... not a fact). And yes, all of these cars are NOT spare no expense cars as well. They too came with compromises from the factory to fit into the target price point.
#41
Agree. The "criteria" includes choosing parts that will fit the price-point of what consumers would pay for a particular model. Like I said before, the GS is not a no spare no expense car. Toyota did consider the cost when they decided what to put in the car.
In the past, I've owned (2) BMW 7-series, (1) BMW 3-series, and the Acura NSX. I did indeed put aftermarket performance "low-dust" pads on all (4) of those cars..... and to me, they were much better pads than the factory (personal subjective opinion.... not a fact). And yes, all of these cars are NOT spare no expense cars as well. They too came with compromises from the factory to fit into the target price point.
I find it a bit funny when I see that someone has bought a GS 350 F-Sport with 19" wheels and high-performance tires complaining about tire ride and tire noise. Did they buy the wrong car?
#42
Your justification of saying that these cars are not 'spare no expense cars' is a weak excuse. The same could be said for practically any line assembly mass-produced automobile, including the 2019 Chevrolet Corvette ZR1 with a 755 horsepower 6.2-liter supercharged engine that has a top speed of 210 miles an hour, or any number of other performance cars.
I do not own a GS350 F sport nor did I complain about any of the cars I previously own on this forum. You need to reread the posts.
i will accept your personal opinion that the Toyota brake pads are the absolutely best pads in the world.... and that you are the most intelligent person on this planet (subjective opinion). Believing anything else... my golly.... would be too incredible!
#43
Thanks for the entertaining posts but you sir, are obviously living in a world of your own. How interesting it is for you to make a personal opinion and truly believe that it is the end all and that there could not possibly be anything else.
Did I say anything about you owning a GS 350 F-Sport? Did I say anything about you complaining about any of the cars that you previously owned? I think it is you that needs to re-read what I said!
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#44
you are correct. The Toyota brake pads are the absolutely best pads in the whole wide world!!! Nothing else compares and no one on the forum is entitled to their own opinion!
#45
yes sir I will reread it all. You can only be the one on the forum that is correct because the world only revolves around you. With over 4000 posts on the forum, who is anyone else to have an opinion on this forum but you? You are obviously a lifer here.
