Finally!!!
#46
Looks great - definitely adds a nice finishing touch to the rear! Did you add any sealant to the areas where you drilled?
#47
Actually it was not too expensive. It's $265 with the template from Bell Lexus on Amazon. For $577 i got the spoiler, template, illiminated sills, and rear bumper applique. Just the applique is over $400 installed from the dealer. It does come painted as it's a Lexus OEM part. Not a spinoff.
#48
One thing that I always do when installing these is to tape plastic cups inside the trunk under the section where I drill the holes. This catches all the bits of metal from drilling so that nothing falls into the trunk area. Makes for an easy clean up and there are no metal fragments left in the tight little spaces in the tunk lid.
When you install these be careful when removing the liners on the tape as once that stuff sticks you cannot remove it to try to move the spoiler.
#52
When I first purchased my GS my first impression of the power was not good. It seemed that my ES had better acceleration espically in the 35-70 MPH range. I really did not push it too hard since it is new. Some of the forum members had said that the RPM range for the GS was a bit different than the ES.
Well it now has just over 2000 miles on it and last weekend I found a straight deserted road so that I could try it out. I turned off the traction control and went to manual shift mode and floored it. I was shifting at about 6500 RPM and WOW!!! This thing woke up and just took off! My wife was terrified and I wish that I had a picture of her. I can tell you that I had a smile on mine from ear to ear. Once you get it in the 3500-6000 RPM range it really moves.
