gs350 fsport brake grease
i changed my brake pads and its squeeking at low speed when i am stopping.
i would like to know what do i need to grease when changing the brakes also do i need to grease the brake pads shims?
what I use is Permatex 24125 purple ceramic brake grease and I put it behind the shims and also on the edges of the pad and also on the pins and any moving pieces on the caliper, and u have to brake in ur pads and after that u should have no problem, sometimes when its cold it makes little noise and once it warms up it should not make noise, and also what brakes did u use.
teezee1000
10-23-18 08:53 AM
