Trunk noise
1) so I went hunting for noise and was able to reduce the fuel door by sticking a wedge on the door. Will add pic.
2) One thing I can't find is the freakn trunk noise. When you close it, it'll be rumbling. When you open it, it's gone. I opened up the cover and started putting soft stuff on things I think are causing the issue. It didn't help. So I decided to turn off the stereo and started slapping the trunk and heard the noise but still can't determine what it is.
I'm looking for help. Open you trunk and slap the trunk (passenger side, right below the tail light). Let me know if you isolate the rattle.
3) I also remove the cover of the license plate light (it rattles there too and it's not needed and you can't see it anyways).
What kind of rumbling noise are you having? Does it happen at a constant rate or when you go over bumps? Cause I know I messed with my trunk liners because I installed coilovers and later on in the future, I started to hear rumbling noises and I thought it was my suspenion, checked everything not it.
Problem was the top of my trunk liner. There are clips that you wanna make sure it's securely fastened and that the liner isn't flapping around either. It came off loose and just started flapping and making noises, hope that helps
