Strange Rear Rotor Issues
Old 05-13-16, 05:53 AM
Igor911
Igor911's Avatar
Default Strange Rear Rotor Issues
Had my car in for service the other week when the advisor mentioned that my rear pads needed immediate replacement and rotor resurface. Since I'm mechanically inclined, I decided to order OEM rotors and Akebono pads.
After taking off my rear rotors, I noticed some interesting issues on the backside. Rotor appears to have strange wearing...almost as if there's an issue with the calipers? Both rear rotors looked the same which is what's more odd.
Long story short, after replacing the rotors/pads, I am now seeing that the pad isn't biting the entire rotor. If you notice the outer-edge of the rotor, it doesn't seem like the pad makes contact?
On the contrary - the car seems to brake fine at all speeds...nice and smooth. Any ideas or is this appearing normal post installation? Thanks in advance...
Attached Thumbnails Strange Rear Rotor Issues-img_7785.jpg   Strange Rear Rotor Issues-img_7800.jpg
Old 05-13-16, 06:00 AM
MrKoo
MrKoo's Avatar
Holy crap did you let your car sit for a while before and let rust build up? Onto the new rotors though sometimes aftermarket pads don't cover the whole surface area like oem pads do. Compare the two in size and how they sit in the bracket...
Old 05-13-16, 06:01 AM
Igor911
Igor911's Avatar
I drive this car daily...it doesn't sit. New Akebono pads are same as the OEM in size... many other folks highly recommend these pads on our forums.
Old 05-13-16, 07:02 AM
SRC350F
SRC350F's Avatar
Igor need some assistance? gives me a chance to see your GS too lol
Old 05-13-16, 08:03 AM
bclexus
bclexus's Avatar
Received 2,274 Likes on 1,620 Posts
Damn!
Old 05-13-16, 08:19 AM
mrpartsman
mrpartsman's Avatar
damm , that I have not seen, and its only on the inside which it the piston side, the only way that would happen if the piston was not coming out all the way, because no way that would ever happen, so if I were you take the wheels off again and look at the inside make sure its the same wear on the outside, unless your piston is frozen.
Old 05-13-16, 08:57 AM
bclexus
bclexus's Avatar
I'm guessing the caliper/sliding pins are sticky or terribly corroded. I never would have expected a daily-driven, late model vehicle, to have rotors and brake pad contact that look that bad.
That rotor looks like something from an old, poorly maintained car, that's been sitting in a junk yard.
I'd like to see the other side of that rotor...
Old 05-13-16, 09:03 AM
Davenlei
Davenlei's Avatar
Is that one of Mater's rotors?
<<Disney's Cars for those without kids>>
Old 05-13-16, 10:39 AM
Igor911
Igor911's Avatar
Just got back from the dealer - they claim that water somehow got in between the pads and rotor?
Who knows? I ended up replacing the rotors and pads - now all appears to be OK
DBCOM
NX - 1st Gen (2015-2021)
10-04-18 03:50 PM
skottydznt
Suspension and Brakes
12
04-08-17 02:05 PM
lieup
02-26-14 05:07 PM
passnu2
01-02-11 05:28 AM
mdsbrain
IS F (2008-2014)
01-26-10 06:06 PM
Quick Reply: Strange Rear Rotor Issues
