Fog Light Fuse
Old 05-16-16, 01:19 PM
frotiss
frotiss's Avatar
Default Fog Light Fuse
Hey Guys I look through my manual three times I am trying to find my Fog Light Fuse any help will be great. Thanks
Old 05-16-16, 01:46 PM
mrpartsman
mrpartsman's Avatar
what year and do u have the base model?
Old 05-16-16, 01:59 PM
frotiss
frotiss's Avatar
2014 Base model AWD
Old 05-16-16, 02:00 PM
frotiss
frotiss's Avatar
I look in the manual from page 644-672
Old 05-16-16, 02:07 PM
rijc99
rijc99's Avatar
Try this diagram...
Old 05-16-16, 02:12 PM
frotiss
frotiss's Avatar
Wouldn't have a fuse amp like 10, 15 etc or location diagram like position number 3, 4 5 etc
Old 05-16-16, 03:24 PM
rijc99
rijc99's Avatar
I've attached the complete Headlight wiring diagram. It doesn't look like the fogs get their power from a specific fuse in the fuse box. Power is controlled through the integration relay. There is no fuse between the relay and the fog light assembly itself.
File Type: pdf
Old 05-16-16, 03:25 PM
Jeevz
Jeevz's Avatar
Try position 19 - 30A or position 27 - 50A in the engine compartment.
Does anything other than the fog lights not work?
Old 05-16-16, 03:30 PM
rijc99
rijc99's Avatar
Here's the Problem/Symptom table.
File Type: pdf
Old 05-16-16, 03:35 PM
frotiss
frotiss's Avatar
My Fog light is working I change to HID so I wanted to up grade the Fuse
Old 05-16-16, 03:40 PM
rijc99
rijc99's Avatar
Oh, I guess all the technical stuff I sent you is overkill then. If I were you I would just run the HIDs with the current stock fuse set up.
Old 05-16-16, 03:42 PM
frotiss
frotiss's Avatar
Thanks I will do that.
avu858
SC- 1st Gen (1992-2000)
06-02-11 02:58 PM
Baybarea
39
07-03-07 05:45 PM
tcho82
04-18-07 06:32 PM
Quick Reply: Fog Light Fuse
