Wheel width/offset for 2014 GS350 on air
I'm not sure how much fender work I would need with a wheel set up that I'm really interested in getting, so I'm writing this thread to get an idea. I will be on air and prefer not doing anything major to the fenders just yet. The wheel setup I'm looking at is:
19x9.5 +20 Front 19x10.5 +20 Rear
Thank you!
Thank you!
i'm running 20x9 +30 and 20x10.5 +35 in this photo before my fenders started getting pulled on the fronts and I did little more pulling in the rear..
235/35/20 and 275/30/20.. only shaved rear fenders in the photos below with as much negative camber possible within reasonable toe specs with stock suspension components.
![](https://c1.staticflickr.com/1/742/22487342927_e5727ed5d9_b.jpg)
![](https://c2.staticflickr.com/6/5648/22892942052_48cd1dc579_b.jpg)
![](https://c1.staticflickr.com/1/738/22896850242_12de531b95_b.jpg)
now i'm at 20x9 +20 with 235/35/20 tires in the front but same specs in the rear.. still rub in rear when aired out and fronts do too but only because fender liner... heh... i did hammer in some of the tabs so driving straight tucking tire is doable.
