LED Turn Signal DIY
#31
I did not mount the resistors for the rear signals. The space was tight enough to wedge the resistor in and not flop around.
#32
Originally Posted by trbosmitty
http://store.ijdmtoy.com/No-Hyper-Fl...s-p/20-001.htm
#34
I'm not sure as both sets of bulbs that i bought require resistors.
#36
#37
So dope I wish Lexus would stop cutting corners and give us this without hesitation we pay a premium and our interior lights is still halogen wtf??
#41
#42
Anyone try to install this one? Looks like it doesn't have the extra decoder box, but doesn't hyper flash or send error codes either.
http://store.ijdmtoy.com/No-Resistor...x-cree.htm#top
#43
So do the resistors that come with this kit get hot, or is it a decoder box to eliminate hyper flash? If it's the first then I wouldn't mount them in the trunk. They could get super hot and melt the trunk lining or even cause a fire. If it's just a decoder then no need to worry. I have the v3 tritons and they have actual resistors so to avoid any fires I place two resistors in the engine bay mounted to metal with high heat 3m tape. FYI if anyone does opt for the V3's you only need one set of resistors to eliminate hyper flash for both the front and back sets..
#44
