LED Turn Signal DIY
#78
#83
Originally Posted by Brent1944
So why is it so easy on the 2016 and not earlier es 350s....
#85
#87
Does anyone have instructions on this for a 2016 ES 350? For both the rear and front and bulbs uses? and if resisters are required??
#88
#89
Yep, it's the exact same ones. I used them for both front and back turn signals. They come with the decoder/resistor. For the rears I just wedged it (the decoder) behind the trunk lining. For the front I did the similar mounting like the OP.
I've used a lot of LED bulbs in the past (for previously owned vehicles) and these bulbs are the best by far.
#90
http://store.ijdmtoy.com/No-Hyper-Fl...20-001.htm#des (same as OP)
http://store.ijdmtoy.com/Error-Free-...s-p/20-009.htm (CREE LED) Is this the one you have?
