LED Turn Signal DIY
#91
Yes, these are the same part number I purchased:
http://store.ijdmtoy.com/No-Hyper-Fl...20-001.htm#des
The picture does not display the decoder, but again it's the same part number I ordered.
#93
Changed the front turn signals to LED on my 2017. Much easier to change them compared to MY2013-2015. They are much brighter than stock, and now they match the rear turn signal and mirror indicators. Highly suggest this simple mod to MY2016+ owners. Would take less than 10 minutes.
EDIT: think we have the same bulbs lol, guess mine are that bright too
signdetres (06-04-18)
#95
thanks for the great instructions. I swapped mine out today and had no trouble other than some scraped hands from the fronts. The rubber housing on the LED units takes a bit of work to get it to "seat" but it's obvious when they fully pop into place. Maybe overkill, but I wrapped the connection between the old bulb base and the new connector.
I ordered the amber for the rear, but the OEM bulbs were white when I removed them. I wonder if the white LED are any brighter than the amber ones? I ordered mine a month or so ago and although they light amber, they look white when off, so no "egg yolk" look when viewing the front ones through the clear housing.
#96
I'll also be looking into changing out the rear amber bulbs to LED amber bulbs
#97
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20180327_212222_029d3e01406eb3c45a3adc035b408ca97ec731e9.jpg)
20-001 amber
#99
yeah that right there is a resistor that actually gets hot! Be careful where you mount that. It’s for sure not a decoder box.
#101
Is there a hyperflash effect on a later model gs (where the only non led bulb is the front indicator)?
I'd prefer just a simple T20 bulb in a factory socket, e.g.:
https://www.osram.com/am/ecat/LEDriv...t/ZMP_4053035/
Thanks!
Thanks!
#105
The weather is nice now and this is an upgrade I've wanted to do for a while. But this seems like such a pain and also don't look forward to dealing with a resistor smh. I already converted my rear turn signals to super bright LEDS with a built in load resistor but I won't be able to install those same bulbs in the front without hyperflash. Has anyone had success with a decoder with their bulbs?
