TPM Sensor Problem on New Wheels
Old 06-21-16, 04:39 AM
Kane007
Kane007's Avatar
Default TPM Sensor Problem on New Wheels
Hi Guys, I finally pulled the trigger last month and bought a set of GS350 F Sport wheels with new tires on ebay from a company called Detroit Tire and Wheel. The wheels are a black chrome finish and I absolutely love how they look.
The problem is, they installed TPM sensors that apparently are not pre-programmed. So when I went to my local shop for them to link them to my car, each sensor apparently is showing as the same number and "duplicate sensor" comes up on the TPM scanner machine. They tell me that the company should have installed pre-programmed sensors as these ones need to be programmed for my car first before they can be linked to my car.
They tell me that the Lexus dealer should be able to program the sensors without taking them off the wheels and then link them to my car, is this true? I dont want to have to spend hundreds and hundreds of dollars to have the wheels and tires dismounted to install new sensors.
Any feedback would be great, thanks in advance!
Old 06-21-16, 08:21 AM
richard203
richard203's Avatar
dealer need to know the tpms sensor id in order to program the tpms.
Old 06-21-16, 08:32 AM
Kane007
Kane007's Avatar
They cant pick up this info with their TPM scanner? I dont have the sensor ID info, I hope Lexus can still reprogram these!
Old 06-21-16, 08:42 AM
LexRuger
LexRuger's Avatar
I had this problem. They are probably aftermarket and not compatible. Dealer will probably tell you to buy OEM. Expensive but it will save a lot of hassle.
Old 06-21-16, 10:25 AM
Kane007
Kane007's Avatar
I was at my local firestone shop this weekend, they say they can pick up the sensors and they appear to be correct, however they are not pre-programmed so each sensor is showing as a "duplicate" sensor. The wheel place that I bought them from said that they used genuine Lexus sensors, I am not 100% sure if they really did or not but I hope that the lexus dealer can still reprogram these.
Old 06-21-16, 05:52 PM
richard203
richard203's Avatar
ya they can use that too, and most of the aftermarket tpms don't work too.
Old 06-22-16, 11:10 AM
er34
er34's Avatar
The sensors can be accessible by just breaking the bead, without actually dismounting/remounting/balancing the tire, but it is an inconvenience that could've been avoided had the tire shop recorded the sensor IDs prior to mounting.
Old 06-22-16, 11:18 AM
Dallasguy1
Dallasguy1's Avatar
Call the SA at the local dealer he'll be able to give you the exact info on the phone.
Old 06-22-16, 11:31 AM
rijc99
rijc99's Avatar
Use the correct tool and re program the sensors.
Old 06-22-16, 06:08 PM
Rozay604
Rozay604's Avatar
Ateq vt30 trigger and reader tool and ateq quickset. That's what I use to program aftermarket wheels
Old 06-22-16, 10:28 PM
djrabbi
djrabbi's Avatar
My local tire shop did mine with no problem. I had same issue and they just re-programmed them for $25
Old 06-23-16, 04:48 AM
Kane007
Kane007's Avatar
Good news...my lexus dealer was able to successfully reprogram the sensors. They charged $125 plus tax, quite a hefty fee just for reprogramming.. but the wheel shop I bought the wheels from reimbursed me for this, great company they seem to be.. so I am a happy guy now. Thanks for all the feedback!
natedahms
04-09-09 09:12 AM
Yes
01-30-08 03:48 PM
salmo
09-21-06 08:31 PM
camillian
09-22-05 01:20 AM
dingo
10-27-03 03:36 PM
Quick Reply: TPM Sensor Problem on New Wheels
