Anyone put a dash cam in their GS350?
#61
there is couple of fuse you can tap into under the glove box.
I just purchased a 2017 GS 350 and want to install my dash cam, however I don't want it to stay on all the time. I know the above said that it was a constant 12V, but before I go pulling trim panels do you know if there is a switched 12v source under the glove box?
Any help would be appreciated!
Thank you for the great write-up
-Joe
-Joe
#63
Models that fit include the StreetGuardian SGZC12RC, the Viofo A119 Series, and the forthcoming slim StreetGuardian SG9663DC as an example.
#65
The top of the rear sun shade touches the rear camera - but just barely. Definitely not enough to cause it to detach - I've had it almost 2 years now, and I haven't had to touch it yet (despite using the rear sunshade very often)
#66
Furthermore, the 650 Series rear dashcam runs at a low bit rate, because a single CPU must process data from 2 channels simultaneously, the bit rate from each channel must be reduced, unless a bigger, faster processor, requiring much more active fan or liquid cooling is used - hence the low bit rate compromizes the video quality.
Below is a video comparing a Blackvue DRS-650 single channel front camera to a StreetGuardian SG9665GC in low light; the StreetGuardian kills the Blackvue already.
If the StreetGuardian is compared to the rear of the dual channel Blackvue DRS-650 Series, it will kill the Blackvue further.
