Driver's side fuse box cover
So I tapped into the inside fuse box to hard wire the radar detector however the fuse tap is bigger than the low profile fuses so i can't put the white cover back on. Could this potentially be a problem if I leave the fuse cover off?
I tapped the passenger side fuse box and had to jettison the cover as it won't fit over the tap. Since the panel is behind the lower glove box panel it can't be kicked so I'm not worried.
YODAONE
05-11-19 01:19 PM
