Yes my headlights still have that part Nixus. Also I did not re-use my front sensors since they don't fit the new sensor brackets. I completely turned them off. You will also need to cut the brake ducts on the F-sport. Not sure if you do on the lower trims
Someone mentioned earlier that you would be able to salvage the sensors if you cut the whole bigger to make them fit the new bumper. Also, what brake ducts are you talking about?
I have an F-sport so I have brake ducts at the bottom of the bumper. Also the brackets and positioning of the sensors behind the grill and bumper made them hard to attach. Specially behind the grill because they're so recessed
so your your gonna use the 2013+ headlights and the 2016 bumper? i wanna see this done cause im interested too.
Yeah i'm looking at my options but I think this is the way i'm gonna go. I can't find a set of 2016 headlights right now. I was also told that the 2016 non triple beam headlights should be plug in play with my car, can anyone confirm this? I really hope the sensors won't be an issue because everything else looks pretty easy without too much work.
Hey nxxt what options would i have to be able to use my old sensors? I have a guy thats gonna sell me a 2016 bumper but i don't want him to drive out if I can't get the sensors to work. Any advice?
The 2016 headlights are not plug and play. They both share the same connector so if anything the triple beam may be plug and play with a non triple beam '16+. The sensors don't fit. Either do some custom work or run the '16+ sensors re-wired somehow. It sucks lol
Could you go into detail in why they wouldn't fit? From the looks of it it seems like I can drill a bigger hole into the 16' bumper and put the old ones in. The only issue it looks like would be that the parking sensors would need some custom mounting.
They need custom mounting for sure. Not sure about the hole size because the brackets on the new bumper don't allow you to test that. On the grill area they definitely don't work. You need a really long sensor for those two as the grill is pretty thick compared to the old bumper center piece
Crap. Ok Thanks for the info man. Ill see what im able to do with it.
Well i'm most likely gonna use the f sport grill and the hole for the sensor is shorter than the non f sport grill so i think it'll be easier. Im hoping that the shop will be able to custom mount them in. Here are some pics of the grill to see what im talking about and a photoshop photo of what it would look like with a non f sport grill. The last photo is of the sensor on my car now.
Hi dudes!
where i can buy front bumper for facelifted GS? i have led headlights, but they cant fit to my 2014 bumper sure
im search on ebay but no resuts
The 2016+ facelift is a big job.
If your doing it just to update the grill, you can also:
2) Use the factory Lexus GS350 2013-15 F Sport Front Bumper/Grill
-- Add Skipper Front Bumper Garnish (or paint the center bumper section matte black)
-- Add an F Sport Lip like AIMGAIN, Lexon, or Skipper
