Just Installed Invidia Q300 Axle Back
Old 06-21-17, 07:52 AM
LatinLS430
LatinLS430's Avatar
Originally Posted by Boombai
I'm thinking of getting the q300 axle back also, so whats the solution to this gasket that comes with the exhaust not fitting? Do you use the original instead?
I used my OEM gasket and haven't had any issues.
Old 06-21-17, 11:04 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Yes you use the oem gaskets.
Contact us for pricing on the exhaust.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 07-15-17, 02:06 PM
trinhtd
trinhtd's Avatar
Originally Posted by slainla
For my first mod, I chose to get the q300 axle back exhaust. I finally installed it to today and am satisfied so far. It definitely sounds louder than stock but it's not overbearing. However, I have a few of my questions below that I hope people can answer for me. Thank you all.
  • Do I need to reset the ECU or is it just plug and play?
  • Is the donut gasket (in between midpipe and axle back joint) supposed to show? The donut gasket that came in the box is thicker than the stock (old) gasket and it creates a slight gap. Even though there is a gap, the gasket appears to be sealing everything. I'm pretty sure I installed the spring loaded bolts and nuts correctly but I just wanted to double check.
  • How long does it take to get the burning plastic smell to go away?
where does the metal rings go that came with the kit?
Old 08-03-17, 01:35 PM
minhael
minhael's Avatar
I just installed mine Q300 too and noticed the hanger doesn't have that bumper near the end and can potentially becomes loose. I had to zip tie the pole haha...
Attached Thumbnails Just Installed Invidia Q300 Axle Back-20170803_135637.jpg
Old 08-03-17, 06:15 PM
richard203
richard203's Avatar
that is dangerous, most of the hanger have a nipple to stop from coming off, u should ask people that have it or ask the seller.
Old 08-10-17, 06:44 PM
hihelloray
9th Gear
hihelloray's Avatar
if its the axle back only just use the supply exhaust donuts and use the stock bolt and spring but use the nut they provide and make sure its tight. thats how i installed mines and it sounds great
Old 08-10-17, 08:16 PM
trinhtd
trinhtd's Avatar
dont worry about that once all the rubber hanging are on the axle back barely has room to move around its not gonna fall off
ZAM
RC - 1st Gen (2015-present)
03-04-19 03:35 PM
LatinLS430
09-16-16 01:22 PM
is350FS
Performance
35
02-10-15 08:41 AM
panda08
Performance
13
10-29-12 10:09 PM
chi123
Performance
11-02-11 10:02 AM
Quick Reply: Just Installed Invidia Q300 Axle Back
