20" Wheels with Tanabe NF210 Alignment Question??
Anyone here with 20" wheels dropped on NF210's was able to get factory specs after an alignment? How close was the camber back to stock specs? I am currently on 20" without a drop and I already have about -2 or -3 camber. Was wondering after drop and alignment would correct this?
I heard from another thread that the RSR Super Downs was not able to get the stock specs dialed in since the drop was past the range of stock adjustments. The NF210 has a mild drop so can be adjusted?
Well SPC makes a camber kit for our cars, I believe that it will adjust up to 3 degrees. I just dropped my car on RSR coilovers with the camber kit and am getting it aligned today. Will report back if I'm able to get it back within spec.
My car was perfect on stock rims but as soon as I put the new rims on, it had negative camber without lowering yet.
