hyperflash fix?
hey guys,
I finally got an set of led turn signals and the dreaded hyperflash came in.. How can i fix this?load resistor? also, i have an set of rear's coming in too. do i need an set of resistor's in the back too to fix hyperflash?
thanks.
thanks.
I used something like this successfully in my Acura. Bear in mind, they get VERY hot so keep them away from other wires and/or plastic material.
http://www.ebay.com/itm/2-PCS-50W-6o...tTFZZ8&vxp=mtr
What brand are your LED turn signals? I have the V3 tritons and they only require one pair of load resistors to eliminate hyper flash for both the front and back. The load resistors do get extremely hot so I don't recommend you mounting them in the trunk. I mounted mine in the engine bay attached to metal using high temp 3m tape. No issues what so ever and I'm super happy with them.
irhasIS350
03-26-12 06:31 PM
