Rear window vandalized! Cleanup/repair advice?
Went to leave for work and when I closed the driver's door I heard a noise. It was part of the rear window falling. My '13 GS350 that I purchased in January got hit by vandals last night. Normally park in the garage but didn't last night. Really frustrating.
Does anyone have advice for cleaning up the broken glass other than using my shop vac? There are a few small pieces of glass in the rear seat area. Is it hard to remove the rear seat back/bottoms? I'd like to vacuum and shake them out.
I have a quote on replacement Lexus glass of $950 for the part. Getting an aftermarket quote tomorrow. I'm inclined to go with original and I think it won't matter much with insurance covering anything past my deductible.
Wow, that's terrible. Now for the big question, did they hurt the MR2?
Most rear seat (bottom) cushions come out easily, but I cannot quite figure out how to remove mine either. Feel along the bottom edge (where the bottom seat cushion meets the carpet) and you'll notice clips/mounting points - one on each side of the bottom cushion. Normally these just pop out. My Acura had a tab that you pulled towards the front of the car and it would release the clip. Hopefully someone else can chime in that has successfully removed them.
I agree that this would be a much more thorough way to clean all the tiny pieces of glass.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
So my wife broke out the back window in her M3 recently (different circumstance, she was trying to remove it intact) and she had the following advice.
1) Definitely remove the rear seat asap to keep from more damage (vacuum carefully first). Watch out for cuts on the leather and if you have some make sure your insurance covers the repair.
2) Shop vac is your primary weapon - get everything up you can see after you get the leather out.
3) Once you do, she recommended you put down some paper or a dropcloth over everything you can because glass will keep falling out every time you touch anything and will also shower down when the professional come to remove your window and replace it (although they'll probably have their own)
4) Also use masking tape to cover up any carpet edges where glass shards could get in that are exposed from removing the seats
5) You should have expectation the window guys doing the repair will take care of the rest
DallasDave, Thanks for the video. And no, the MR2 was untouched.
DaveGS4, that's great advice. I started the cleanup with the shopvac and occasionally bits go flying so a drop cloth is in order.
It sounds like insurance may cover taking it to the dealership for seat removal and cleanup. If so, I'll do that. Definitely getting OEM glass. Deductible is $500 and aftermarket glass is more than that.
Yep, always, always replace with OEM. Years ago, insurance companies would cheap out and go aftermarket every chance they got. Reform laws were passed and insurance companies can only give recommendations now and if you insist on OEM, you get OEM, and you even pick the shop that replaces it.
OEM it is. All set for Monday with the glass company that the dealership recommends.
I'm concerned about glass that fell in the rear automatic sunshade. Once the new window is in place, I'm going to ask the dealership to disassemble the sunshade to clean it out along with pulling out the rear seats. I'll have to submit that expense to the insurance company for reimbursement. Hopefully they don't hassle me about it.
Not a lot of DIY videos and explanations out there for the 4th Gen GS yet. I'm used to the MR2 where everything's been taken apart and documented in excruciating detail online.
So, if it's glass I think you have the advantage. Now for bumpers/body panels I'm not certain, but here's my logic (and my argument to my insurance company): if using non-OEM parts can lower the value of my vehicle I strictly refuse to allow them to use them.
Here are some interesting articles:
http://thelawdictionary.org/article/...n-connecticut/
https://www.cga.ct.gov/2009/rpt/2009-R-0398.htm
http://www.insure.com/car-insurance/...ts-rights.html
WJSOLOMON
12-20-04 12:36 PM
