Alignment from Lexus after lowering?
Old 08-21-16, 12:05 PM
kamskeez
kamskeez's Avatar
Default Alignment from Lexus after lowering?
Hi all. Has anybody taken their car to a Lexus dealer for alignment after lowering? I just installed springs and adjustable rear camber arms and need to take it in for an alignment. It's not much more expensive than my local shop ($130 vs $100) and it'll make it on the dealer's rack, so I was wondering if anybody had any experience with getting it done at the dealer. Thanks!
Old 08-21-16, 12:31 PM
Sevn86
Sevn86's Avatar
I don't have any experience with my dealer as they were asking too much ($160) so I just took mine to Brake Check and bought their lifetime alignment. All I pay now is about $3 each time I need one.
Old 08-21-16, 12:47 PM
y2tony3
y2tony3's Avatar
When I do any mods I usually try not to take it to the dealer because most of the times they can be a**h*les and say oh you did so and so that voids your warranty. Plus I don't see what the difference is from dealer work to a reputable alignment place. Plus when I called they were charging me $300 for an alignment... I was like what the buck... So I just researched, yelped and found a guy that actually does alignments for dealerships and he only charged me $80 bucks... The guy is really good too. Happy with the results.
Old 08-21-16, 02:47 PM
shurik74
shurik74's Avatar
I never do anything at dealer if it's not recall...
Don't forget to take couple weeks for your GS to settle on your new springs before alignment! Mine dropped on 3/4 inch after 9 days...
Old 08-21-16, 04:19 PM
kamskeez
kamskeez's Avatar
Good call about the warranty, I'll have to double check that as well. Thanks for the input!
Old 08-21-16, 04:24 PM
kamskeez
kamskeez's Avatar
I'm giving mine a week to settle. I didn't want to wait too long because I do have new camber arms installed as well.
The dealer would give me an overnight loaner car as well. Hmmm......
Old 08-21-16, 05:12 PM
GSLexTexas
GSLexTexas's Avatar
Is it really necessary to get camber arms after a drop? What if you just get an alignment without it?
Old 08-21-16, 06:42 PM
kamskeez
kamskeez's Avatar
It depends on the drop you do. If you go conservative (ie, rsr downs) then you probably won't need a camber kit. But if you go lower (ie, coilovers) then a standard alignment won't get your camber back within factory spec, so you'll end up with some uneven tire wear.
Old 08-21-16, 09:06 PM
Sevn86
Sevn86's Avatar
I have slight uneven tire wear with just 20" wheels and no drop. So I'm actually looking at getting a rear camber kit.
Old 08-21-16, 09:15 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,050 Likes on 664 Posts
They'll probably mess up ur car more than fixing it. I'd take it to an independent shop that specialized in lowered cars.
Old 08-24-16, 02:28 PM
GSLexTexas
GSLexTexas's Avatar
I plan on going with RS-R super downs on my non Fsport, which lowers the car about 1.4" (I think RS-R super down only drop 1" on Fsports?).
I guess I'll need just the rear camber kit.
Old 08-25-16, 12:22 AM
kamskeez
kamskeez's Avatar
I went to an independent shop and with the camber arms, they were able to get everything back to within spec. Very pleased!
Old 08-26-16, 09:57 AM
shurik74
shurik74's Avatar
So... I went with 20x10.5 + 275/30/20 on rears with camber kit, after proper alignment my wheel is rubbing fender with people sitting on the back, need to do fender roll now. Kinda upset cause I was sure that it won't happened after reading bunch of threads here. Most likely, my mistake was with not paying enough attention when reading, guys who did not have rubbing they were w/out camber kit. My initial pick was 20x10 on rears but Vossen rep convinced me that 10.5 is our recommended and you should go with 10.5. Pardon for english, hope I was clear.
Old 08-26-16, 11:01 AM
mrkwinning
mrkwinning's Avatar
By the looks of that, even with a fender role you will still be hitting the sidewall.
Old 08-26-16, 03:35 PM
shurik74
shurik74's Avatar
Anyway... what got me thinking is... We have many people here with exactly same set up! Why me who is rubbing? Am I missing something?
Quick Reply: Alignment from Lexus after lowering?
