Illuminated door sills installed!
Finally got around to installing these today. The instructions that come with them are crazy. They want you to take apart half of the interior to wire them up. There is no need for that at all..so those of you scared to install them yourself, don't be. It takes 15 minutes a side to wire them up. Just take off the lower panel that houses the LED floor light and you're good to go. If you have any questions about the install I'd be happy to answer them!
Here are some of the best DIY threads that people from ClubLexus have contributed in the past (which you could use as a reference): https://www.clublexus.com/forums/gs-...ere-first.html
Would really look forward to something like this,
~ Im2bz2p345
As soon as I submitted my post, I thought of another question. Don't the floor lights stay on all the time? I realize they are dim and get brighter when the door is open/car in park/etc. Doesn't that mean the sills will do the same? Does it really matter, as they will be hidden when the doors are closed?
I would be curious to know if the instructions tell you to use a different source as to NOT have the dimming effect.
bestlexus - 2013 GS350
DallasDave...the instructions actually tell you to tap in to the floor lights. The wires coming from the sills are the exact same color, so you can match the colors and tap right into them. I used my power probe to make sure they were correct before tapping into them, and they were. If you've taken the panels off before, this should be a breeze. The drivers side has 3 screws and 2 clips. The passenger side is just clips.
Speaking from experience on this install, you need to tap the power source of the dome light. That's the way it should be. You open the door, the dome light comes on and the sill lights come on.
Easy way to see if the lights go off when the door is closed, is to leave the door open and press the black nipple thing on the door frame that tells the car the door is closed.
Did you order the sills from Lexus USA, or the ones for JDM from Nigel? Price difference has always made me scratch my head.
They are the USA versions, not the JDM(is there a difference?). As far as tapping the dome light, that doesn't make sense since it will be much harder to find that wire considering it probably runs down the A-pillar or is buried behind the fuse box. The floor lights are essentially the same thing..open a door and the sills come on. Do the floor lights have power while the car is running? Yes..but we are talking about LED's here..not halogens that consume more power and burn out over time. The LED's should last the life of the car, and with the door closed you won't even know the sills are still illuminated.
illuminated door sills
The installation appears to be more difficult on a 2014 ES350. I have pictures if you want to see them. There are numerous pieces of wire wrapped up. Would guess about 10-15 different ones. So I don't think it's as easy as it sounds. I can send pics on email.
Every set of instructions I have seen, and other installs I have seen..all tie in to the floor lighting. Like I said though, it's all relative and really doesn't matter as they are LED's and the only time they will be on is with the car running, and you can't see them anyways.
Sent you a pm.
