Rubbing issues on driver front side
I have a 2014 gs350 f sport lowered on tanabe nf210
vossen cv3
20x9 F 245/35/20
20x10.5 275/30/20
im only have rubbing issues on the driver front fender liner and it looks like the metal bracket where the bumper screw on to the fender area... can y'all give me some feedback ?
vossen cv3
20x9 F 245/35/20
20x10.5 275/30/20
Measure from gender to ground on both sides to make sure they are sitting (the Tanabe springs) properly in the perch. If one side is higher or lower then you know the spring might be the problem, if not then you might have to go with a lower profile tire or different brand same size
I run a +33 9.5 front with 245/35/20 and I only run when I hit a huge dip in the road or in reverse with wheel fully cut left. Since I switched from the Tanabe to RS-R Springs it rarely ever happens, the Tanabe have a lot of bounce, and the RS-R Superdowns are stiffer spring..more pics and comparisons in my build thread
