Warranty
My check engine light came on and was wondering if a smart throttle control, midpipe and back axle exhaust or k&n intake can void warranty? thank you in advance
CEL is usually attributed to smog equipment. Could be also the gas cap being left off, O2 sensors, Cat converter, MAF, Spark Plugs. If you removed your cat converter when you installed the mid pipe, it could void your warranty. If the K&N is carb rated it should be fine. Just set your throttle controller to off. Just to be safe put back the cats when you take your car for warranty work.
What's the code?
holyking
08-05-10 02:18 PM
