Keeping the GS "till the end"?
Old 11-17-16, 07:07 AM
GSdre
GSdre's Avatar
Originally Posted by dat dude
Hi All,
As the title says, I want your guys opinion on how you think the GS will fair after the 8 year mark. I really do plan on keeping the GS till the end (whatever mileage that might be). Do you think the computer will last, engine life etc etc.
Your input is greatly appreciated!
Thanks!
I must say, my GS300 (1999) is 16 years old , I have minor things wrong with it such as worn suspension and a few codes , but with all that said , I have owed cars that would break the minute something was wrong , it's been 3 years of owning this car with the same issues I got it with , and it is consistently reliable. I give the GS model a 9.5 in one of the most reliable cars ever made.
Old 11-17-16, 08:31 AM
lamikela1
lamikela1's Avatar
GS brake by wire??? Does the '16 have this as I was not aware of it? I know that PCS will operate the brakes but for normal braking the pedal is still operating the master cylinder mechanically correct?
Old 11-18-16, 02:11 PM
jdigga99
jdigga99's Avatar
Originally Posted by er34
Just look around, plenty of late 90's and early 2000's ES/GS/LS/RX on the road. 8 years is practically fresh off the dealer lot for Lexus.
Good point, I saw two GS2's just this morning on the way to work. One black and one grey, both looked like they had been cared for.
Old 11-18-16, 05:57 PM
Dallasguy1
Dallasguy1's Avatar
I had 2007 GS350 which I kept till 160k with normal maintenance, this generation looks and drives very solid. The other day I saw a '13 with 123k miles.
Old 11-19-16, 12:17 AM
Infamous3
Infamous3's Avatar
Believe me it will. Those V6's are bulletproof
Old 11-19-16, 07:42 AM
roblim
roblim's Avatar
My experience has been that the major components will go beyond 200k easy. But, things like seals, pumps, electric motors will fail and those things can be very expensive if you elect to repair them. They don't cost the same as a new head gasket or rebuilt transmission, but they add up if you decide to stay on top of them. If you are mechanically inclined and research forums like this one you can fix a lot of things yourself, but it also helps to know a reasonably priced mechanic.
Old 11-19-16, 08:32 AM
Ecohman
Ecohman's Avatar
Default Not there yet
My GS is a 2002 with 315,000. Original paint, motor, transmission. Looks good, runs great!
Old 11-19-16, 12:29 PM
Ehsun
Ehsun's Avatar
Default keep it
the lexus gs has already enough luxury and a great powerful engine. this thing will last you
Old 11-19-16, 11:47 PM
Lukas99GS
Lukas99GS's Avatar
Just look at the previous generation gs350s, and is350s same engine, and same 8 speed trans as the ls460 and gs460s and you don't see major engine or trans issues with those. I've seen 3rd GS350s with over 200k and one member on their forum has over 300k
Old 11-20-16, 12:58 PM
AJLex19
AJLex19's Avatar
Received 1,152 Likes on 850 Posts
The GS will last - historically high in reliability for each generation. The GS has the same "genes" as the LS so keep that in mind as well...
Old 11-22-16, 03:55 PM
Stereorob
Stereorob's Avatar
yes brake by wire. no physical connection between your foot and the brakes of the car. I know it sounds crazy and when I first learned about this it freaked me out but found it really interesting so I looked into it. there is a main wire that goes to the braking system that attaches to a multiplex circuit that feeds electric to the actuators. sounds sketchy but its 100% fail safe. there is the main wire that brakes but there are 4 back up ones incase the main one fails. and if the car looses power there are capacitors that store energy enough to brake if theres no power to the car. its also throttle by wire and (almost) completely steer by wire as well. I know it sounds crazy but look into it. the LS is also like this.
Old 11-22-16, 07:16 PM
JDR76
JDR76's Avatar
Received 1,612 Likes on 1,028 Posts
It's not steer by wire at all.
Old 11-23-16, 05:28 AM
Stereorob
Stereorob's Avatar
yes and no. its power assisted but electric does most of the work. try driving a GS with the power steering out. its VERY hard almost impossible. same with the current IS and LS. drive it for a few days without it and youll look like popeye the sailor lol
Old 11-23-16, 08:12 AM
JDR76
JDR76's Avatar
Having electric assist is not steer by wire. The steering wheel is still physically connected to the rack and pinion. In steer by wire, there is no physical connection. A computer reads the steering wheel inputs, then sends them to a motor on the rack. The Infiniti Q50 with DAS is the only production car with steer by wire.
silver305
03-22-13 04:58 AM
LetMeShowU
06-07-07 03:22 PM
tiguy99
12-14-05 04:08 PM
Quick Reply: Keeping the GS "till the end"?
