2013 GS450H with IS F Sport wheels fitment?
Hi, I was wondering if anyone on here has tried this either on their GS. Will it fit? Will spacers be needed? I really like the look of the is f sport wheels and was hoping it would fit on my car. I know those wheels are staggered which is fine seeing how my hybrid is RWD anyway. Thanks for your help in advance.
If you have the Non F sport GS450h than the IS F sport wheels will fit for sure as I am using this for my winter setup. F-Sport models have bigger calipers, so this might be a problem.
This seems to be the case. I installed a set of 08' IS F rims on my 13' 350 F-Sport AWD and spacers are required for front wheels due to the large brake caliper. I ended up installing 15mm spacers for all wheels.
Sorry not really, since my car is running the stock rims with winter tires now. But what I can tell you is that those IS F rims do look better and sharper than stock ones And if you were to install spacers, 20mm will be better for rear even if your car is lowered.
Yes you need spacers with ISF wheels ( i have these as well) , but he is talking about IS F sport wheels, which are different, for those wheels, there is no spacer in the front required.
Hi guys, I finally got a set and did a test fit. Everything clears, no spacers needed. Unfortunately, I didn't mount them on fully because I swapped my summer tires onto these wheels and am currently running my winter set now. So more pictures to come in the spring but hope you enjoy in the meantime.
lexus114
NX - 1st Gen (2015-2021)
03-12-18 04:27 PM
