Is dealer 20K mile maintenace worth it?
I do all of my own work as well. You can manually log your work in the Lexus computers by going to "http://drivers.lexus.com/lexusdrivers/" and creating an account.
What is this "check driver's side floor mat" about? It even shows up on CarFax for some vehicles as "carpet/floor mats secured" or something like that.
To make sure the driver's side floor mat is securely attached to the floor connection points so it does not slide forward and trap the accelerator pedal. This was made a topic some years ago when Toyota and Lexus owners complained about 'sudden unexpected acceleration' where it was found that people had not secured their driver's floor mats, or had another mat on top of the OE mat.
SC300Es (01-25-17)
Originally Posted by Dkp1111
Longo has $99 coupon for oil change full synthetic. Beside that i would buy other filters myself and change it. Take 5 minutes max. Btw songoku u paint your caliber how hard is it for you to switch out the filters and wiperblade insert lolz. I would prefer inser over costco or walmart wiper. Had bad experience with both. OEM ftw.
http://www.longolexus.com/Longo-Service-Specials
It looks like they already completed 20K maintenance??
______________________________________________________________________________________________________
16121 miles
DATE: 08/30/2016
Repair# 0425487
reported by: Jim Falk Lexus of Beverly Hills
Service:
description:
USED VEHICLE SAFETY INSPECTION ~ INSPECT CHASSIS AND UNDER BODY INSPECT EXHAUST SYSTEM ROA ~ ~
CHANGE OIL & FILTER REPLACE DRAIN PLUG GASKET INSPECT BRAKE PADS AND DISCS REMAINING PAD FRT---% REAR---% ADJUST FLUIDS TO PROPER LEVELS SET TIRE PRESS
REGULAR MAINTENANCE ~ ~
450 PERFORMED SAFETY INSPECTION - 2.0 CHANGE OIL WITH FILTER, CHANGE CABIN FILTER REPLACE WIPER INSERTS, REPLACE FRONT PADS AND ROTORS -
1.5 REPLACE BOTH REAR TIRES - 1.0 LR DOT#EJN7JDK4315 / RR DOT#EJN7JDK4315 TIRE READINGS: L
REMOVE COMPRESSED AIR FROM ALL TIRES AND REPLACE WITH 99% PURE NITROGEN - WITH 1 YEAR OF TIRE PROT ~ ~
16121 REGULAR MAINTENANCE 0 40
Service: DETAIL ONLY
description: DETAIL ONLY ~
Service: FILL WITH GAS
description: FILL WITH GAS ~
My windshield sticker says that my next service is due "21,121".
I guess they calculated based on 5K miles.
