Let's all post pics of our lowered GS350!
Old 09-09-17, 06:33 PM
  #76
Tldracer24
Tldracer24's Avatar
The following 2 users liked this post by Tldracer24:
bob256k (09-27-18), signdetres (09-28-18)
Old 11-15-17, 05:06 PM
  #77
gte
gte's Avatar
Can you provide an update on this?
Originally Posted by PDF84
Finally got around to swapping out my Tanabe springs for Swift springs as well as installing SPC rear camber arms & Megan Racing front camber arms. The ride is slightly smoother and less bumpy now with the Swift springs, the ride height it also a tad taller than it was on the Tanabes. but I'm ok with that I still think it sits nice. And my front fender doesn't rub anymore when I'm turning the car with the wheel turned all the way so that's a plus. I have only driven it about 50 miles with the new springs so I will need to spend some more time before I can give a good review but so far I'm more happy with the new springs. Now I just need to get it in for an alignment. Here are comparison pics of before and after.
1st pic is with Tanabe NF210 springs (Front spring rate 3.6kg/mm) (Rear spring rate 6.5kg/mm)
2nd pic is with the Swift springs (Front spring rate 5.0kg/mm) (Rear spring rate 7.5kg/mm)
Old 11-15-17, 10:25 PM
  #78
Boomin
Boomin's Avatar
Originally Posted by TarmacSL3
Lowered on RSR Downs
That's great, in this photo how long has it been installed, feeling and notice any camber wear yet?
Old 11-16-17, 01:48 PM
  #79
TarmacSL3
TarmacSL3's Avatar
That photo was taken the day after lowering. Ride is just like stock except for when in Sport + its a little firmer. Its not my daily as I commute 80 miles a day just for work. The car was lowered @2500 miles and then I had my new wheels and SPC camber arms installed at around 3400 miles. Picture below was taken after wheel/arm install. Car is now at about 4500 miles and no camber wear at all.. tires are all even.
gte (11-16-17)
Old 11-16-17, 08:03 PM
  #80
gte
gte's Avatar
Thank you for the RSR down review. Why did you get camber arms? I was not expecting camber issues with the downs
Old 11-16-17, 08:21 PM
  #81
kaminare
kaminare's Avatar
Megan racing coilovers on UAS bags
megan front camber arms
spc rear arms
TrevorTran (11-17-17)
Old 11-17-17, 05:52 AM
  #82
TarmacSL3
TarmacSL3's Avatar
The GS has no adjustment for camber front or rear. After the drop the Front camber was -0.9 Left and -1.1 Right (Factory Specs are 0.6 to -0.9). The Rear was -1.9 Left and -2.1 Right (Factory Specs are -0.7 to -2.2) so both front and rear were right at the spec limits for negative camber, so for peace of mind I went ahead and did the rear SPC arms. With the SPC the rear is now at -1.5 for both the left and Right so right in the middle which is what the factory is normally set at. Only time will tell as I have only put ~2k miles on the car since it was lowered and 1k of that is with the SPC arms.
Boomin (11-19-17)
Old 11-17-17, 08:10 AM
  #83
gte
gte's Avatar
Very detailed, thank you! I will have mine checked and decide if I need those as well
Old 11-18-17, 09:07 PM
  #84
Chavez562
Chavez562's Avatar
Originally Posted by Tldracer24
platinum did it again, another banger! Looks dope!!!
Old 09-26-18, 06:08 PM
  #85
UZS160
UZS160's Avatar
RSR active coilovers
Old 09-27-18, 04:06 AM
  #86
eddie420
eddie420's Avatar
How is the ride quality?
Old 09-27-18, 08:22 PM
  #87
jonathancl
jonathancl's Avatar
I have since removed the clown nose decal. Tanabes, 15mm, 20mm spacers. Not bad for 82k miles. Love this car.
Attachment 487251
Old 09-28-18, 07:26 AM
  #88
TrevorTran
TrevorTran's Avatar
2013 F Sport RWD bagged on Airlift Performance Struts with 3P management
mommings350 (09-21-23)
Old 12-22-21, 09:40 PM
  #89
glogs350
glogs350's Avatar
Default I need help
Originally Posted by JZFsport
Nice. ASF
I need help with a coilover set up 2018 gs 350 f sport
Old 03-15-24, 01:08 PM
  #90
EdgarLex
EdgarLex's Avatar
Bringing this thread back. Might get some better pics later. Lowered on RSR downs.
Dew23
Suspension
03-10-16 11:29 AM
sbrown02
Suspension
41
06-12-13 04:16 PM
DaddyinKC
05-16-12 10:54 PM
grygrl07
03-29-10 05:45 AM
Quick Reply: Let's all post pics of our lowered GS350!
