Auto Folding Mirrors
#76
No you don't need the physical button(I assume if you got one it would be plug and play mod).
The Carista app has the option to enable the auto mode. I guess if you wanted to turn it off you would have to go through the app.
So as soon as I start the car the heated seats turn on. It only turns on the passenger side if someone is sitting in the seat. So I guess when the temperature goes up it will switch to cooled seats.
Yes it's nice not having to press the buttons for me and my passenger. Would have been nice to have the heated steering wheel turn on automatically too, for that I still have to press the button.
Also I was able to disable auto A/C, that way in the winter I can completely turn the A/C off and not have it turn on when I click the auto button.
There are so many useful setting you can change through the Carista app.
#78
Hey peasodos!
First of all awesome write-up on your journey! I love the attention to detail and your bravery in trying this out.
I have a question, I'm considering doing this mod on my USDM IS 350 F Sport. I know that the GS and IS side view mounts are different, but I think the covers could be the same.
I'm considering buying a used 4GS mirror w/ power folding and transfer the internals to my 3IS mirror. You mentioned the motor was on the top portion of the assembly. Are the bases interchangeable between a non-power folding 4GS base and a power folding 4GS base? Does the motor gear up with the base at all? I'm wondering how it actually moves and what holds it there.
Thanks a bunch!
aceforever
Thanks a bunch!
aceforever
#79
Hey peasodos!
Thanks a bunch!
aceforever
Thanks a bunch!
aceforever
aceforever (05-03-18)
#80
Thanks so much for the response! That really gives me hope to continue this project.
Next I'll go take apart my door panel and check to see if my car harness connector to see if there is wiring on all 16 pins. This way I can at least know that wiring supports power folding mirrors. After that, I'll order up a GS side mirror w/ power folding.
Is there anything to watch out for? I found a few that has 13 wires, missing 3 (looks like it doesn't have the BSM light on the mirror itself, I thought the light only uses 2 of the pins on the connector, not sure what the last wiring missing is for)
Do you happen to know of the pinout of the connector or where the power motor is pinned. Maybe I can spot a power folding mirror on ebay based on that.
LEXUS IS PINS (according to chilton), filling it out as I combine all the separate pages info together
1 Vertical Mirror Actuator (MV)
2 Flood light (MLP)
4 Heater +
5 Position Sensor Power
6 Mirror Position Sensor signal (vertical)
7 dimming (EC+)
8 Blind Spot Indicator (BSR+)
9 Horizontal Mirror Actuator (MH)
10 Mirror Actuator Common (M+)
12 Ground
13 Mirror Position Sensor signal (horizontal)
14
15 dimming (EC-)
16 Turn signal (TAN+)
GS pinout
1 Vertical Mirror Actuator (MV) (white)
2 Flood light (MLP)
3 power fold (MR) (Green)
4 Heater + (brown - white)
5 Position Sensor Power (lightblue)
6 Mirror Position Sensor signal (vertical) (violet)
7 dimming (EC+) (brown)
8 Blind Spot Indicator (BSR+) (gray -red)
9 Horizontal Mirror Actuator (MH)(red)
10 Mirror Actuator Common (M+)(black)
11 power fold (MF) (Blue)
12 Ground (black-red)
13 Mirror Position Sensor signal (horizontal) (light green)
14 Mirror position negative (gray)
15 dimming (EC-) (black-blue)
16 Turn signal (TAN+) (pink)
Looks like the pinout is the same! that's awesome.
2 Flood light (MLP)
4 Heater +
7 dimming (EC+)
12 Ground
14
15 dimming (EC-)
GS pinout
2 Flood light (MLP)
#81
2 Flood light (MLP)
4 Heater +
7 dimming (EC+)
12 Ground
14
15 dimming (EC-)
GS pinout
2 Flood light (MLP)
2 Flood light (MLP)
4 Heater +
7 dimming (EC+)
12 Ground
14
15 dimming (EC-)
GS pinout
2 Flood light (MLP)
This is the post that inspired me to try this mod on the GS:
https://www.clublexus.com/forums/rx-...010-rx350.html
#82
All 2014+ Lexus GS have power folding side mirrors, just make your purchase based off that. You can ask the seller what year the car was or the vin the mirrors came from.
#84
Hit a snag, looks like for the IS 350s NOT equipped with memory seats, it will not be be a direct swap between the Master Switch from a power folding to a non power folding.
So in this case even if I get all components:
System Layout:
w/ Memory Seats
Master Switch -> BOTH passenger and driver Door ECUs or also referred to as Mirror Control ECUs
Each Mirror Control ECU -> Side mirror actuators
w/o Memory Seats
Master Switch -> BOTH passenger and driver Side mirror actuators
Since this is becoming more complex, I'm opting to not continue with this modification.
- Master Switch w/ fold buttons
- GS Driver side mirror w/ 16 wires
- GS Passenger side mirror w/ 16 wires
- Driver Door ECU
- Passenger Door ECU
- Wiring to connect these w/ other things
- Mirror folding module, connect it with a button, power, acc, alarm arm, etc...
- Run custom wire to driver and passenger side door to connect to the power folding GS mirrors pin 3 and 11.
System Layout:
w/ Memory Seats
w/o Memory Seats
#85
Hi guys,
got an used gs 350 awd f, mirror auto folding was working when tested the car. Did a data reset and its not working anymore.
i got carista to try to make it work. But nothing is happening. I don't see any auto buttons in the car or carista except the option to make it ignition or door lock. Any ideas?
#86
Hi guys,
#88
I believe they made BSM standard starting the 2016 model year. I think BSM is linked to power folding mirrors. Our 2015 GS doesn't have BSM nor power folding mirrors. In our 2018, where the mirror controls are, you have one button for folding in and out the mirrors and one for turning on and off the auto folding function. If you don't have those controls or BSM, I'd bet the car isn't equipped with it as there aren't any other ways to power fold the mirrors.
SavannahGS (06-03-19)
