<br />Most cast wheels will have issues with bends, especially the larger you go. I bent all 4 rims on my other car with Miro wheels. Even if you are super careful you eventually hit bump or hole in the roads that can bend them. The cheaper wheels are cheap for a reason, they bend much easier.
Every wheel is different case by case.. my cast wheels just cracked on the barrel into the bead seat and it was a small hairline crack after hitting a pothole with 275/30/20 tires at 38 psi on all seasons.
