60k mile maintenance questions
Hey folks,
Just brought the wifes 2013 GS350 F sport into my local dealer for an oil change (she has 62k miles on it). They are recommending spark plugs as well. I wanted to gauge everyone's feedback to see if this truly is necessary and if there is anything else that I should be considering soon service wise? I do plan to keep the car for another 2 years or so. Replacing the plugs requires quite a bit of labor, totalling about $600 for everything.
Thoughts?
Thank you in advance!
Thoughts?
Those spark plugs will last beyond twice the mileage you currently have, and be just as good as they are today. Many car owners go over 200k miles and never replace the spark plugs with no issues or decreased fuel mileage. However, what I do not know is if refusing to replace the spark plugs may cause an issue with any part of the warranty. I can't see how it would, but...
jonathancl (05-11-17)
At 60k miles you will want to change the engine oil and oil filter. Also, replace the brake fluid if you plan on keeping the car for many years to come. You should have the cabin air filter and engine air filter checked to see if they need replacing. Everything else will be inspections, which may find other things that are needed, e.g. brake pads, etc.
► http://www.lexus.com/pdf/service/MY1..._GS350_WSG.pdf (See page 55)
Replacing the spark plugs at 60k miles is 'Required under the terms of the Emission Control Warranty'. Therefore, if you are not concerned with voiding the Emission Control Warranty, then there is no need to replace the spark plugs. I personally would not replace the spark plugs.
Was just going to write about the Emission Warranty requiring replacement to keep intact
Plugs is one of those things that's worth to learn to change yourself, Iridium plugs are right around $10/piece. Granted our cars aren't the easiest to change and there's some stuff that you got to move out of the way to get to some of them, it still shouldn't take more than 2-3 hours even if it's your first time doing it(better if you can find a friend/family who has experience). $600 is pretty ridiculous for plugs on a longitudinally mounted V6... I guess I could see it cost that much for more difficult cars with transverse mounted or boxer engines.
I agree! I normally wouldn't mind doing this myself but the dealer made it sound somewhat complicated.....of course
I used to do all of my own oil changes, filters, etc. Now with a 3 year old, my time is just a bit more limited, ha! I have a buddy who is a Porsche / Mercedes mechanic, so if it comes down to it, I can use him.
https://www.clublexus.com/forums/is-...g-service.html
bigbwb (04-06-17)
Spark plugs normally last at least until 100K miles to well past that, I know several people who did not change them to 200K miles. $600 to replace spark plugs is ridiculous and highway robbery. I would buy your own and just learn to do them yourself and save at least $500+ dollars.
If you drive hard and redline the engine consistently, I would recommend changing it according to the manual.
I had my sport bike since new, the manual recommends changing the spark plug at 10k. I ride it hard and redline whenever possible. At 9500 miles the spark plug failed and caused misfire. After spark plug change, it was running like new again
