Rattle noises from either the glove compartment/trim
Hi, i have a 2015 gs250 fsport and was wondering if any of y'all have a problem with the rattle noises coming from the glove compartment or the trim that is above it? I'm trying to figure out where it is coming from. If i put light pressure on the glove compartment, it stops rattling and if i put pressure on the trim it also stops rattling. I took it to lexus and they tighten all the bolt on the glove compartment but i still hear it. Can someone help me out?
There is TSB for sunroof rattling.
I've experienced the same problem lately. Upon initial investigation, feels like the glove box door itself may be somewhat loose because whenever my passenger puts pressure against it, the noise goes away. It hasn't bothered me enough to try to track it down.
To start, I'll likely remove everything from the glovebox and try to hear the noise again. In the past, I removed the trim around that area to tap the footwell lights for my illuminated door sill install...my best guess for now is that if its not the actual glove box door, it could actually be something around the passenger side IP cover (the piece right below the glove box door) that has become loose.
websurfer (05-26-20)
I've tried everything like removing the tray inside the glove compartment, removing all the stuff inside of there and i still hear it. I have like 1500 miles until my next oil change so ill tell them next time. Last time i took it then, the rattling wasn't constant but now i can hear it every time and it bothers me.
I have went to dealer yesterday and resolved this rattle
it not the welding problem it is caused by the bolt that fix the triangle reinforcement part under the fender.
when the bolt is tighten, the metal of the car body squeezed and make rattle.
the technician just loose the bolt and adjust the location of the nut behind the reinforcement part and the metal piece of the body, then re-tighten the bolt.
the rattle is gone!
the rattle is gone!
Hi all,
i had a similar experience with my 2016 rx
here's the video of the sound i can produce while driving out of parking lot with full turn of steering wheel to the right
Still couldn't find the solution. anyone can help?
thanks
thanks
I had some rattle from glovebox area when driving over bumpy roads. seems there could be multiple spots where it can make noise. I removed the whole glovebox and put some speaker tape over all the contact points. Well now the rattle is gone. But I don’t know for sure which one was the cause. There is never too much sound insulation))
mandyfig
01-14-19 03:00 PM
