Replace factory Nav Hard Drive with an SSD
Old 04-08-17, 09:48 PM
  #31
peasodos
peasodos's Avatar
Received 2,228 Likes on 1,450 Posts
Originally Posted by ChronoR
Btw, does everything other than navigation still work without the hard drive? I kinda want to remove even the HDD whir sound.
I'm not sure. I did start the car with the whole stero out and there are no menus. Putting everything back together.
My solution to quieting the hard drive, covering the tray cover with foam tape. I don't know if it will do anything, but since I had it out...
Old 04-08-17, 10:24 PM
  #32
peasodos
peasodos's Avatar
Put everything back together. If anyone else attempts this and can successfully clone a toyota/lexus hard drive please update this thread.
I'm returning the ssd to Amazon.
Old 04-09-17, 09:49 AM
  #33
aachowhan
aachowhan's Avatar
Wait!
Did you try with linux?
I know in some instances linux can bypass some of the restrictions and also give you better control. It could even be a formatting thing or the software on the drive. Try getting a copy of linux running if you can and see if you can read the files that way.
Although now I'm curious, if you replace the HDD can you also update the GPS and overall Lexus Enfrom system with that? I think is worth a few more attempts. I know someone dumped the GPS update for 2014 models and up so that might have some kind of key file in there.
Old 04-09-17, 10:52 AM
  #34
peasodos
peasodos's Avatar
Originally Posted by aachowhan
Wait!
I already put the stero/nav unit back in the car.
This video shows you how to remove the stero/nav unit. My pictures show the location of the drive in the stero/nav unit. No I didn't try with linux.
Old 04-10-17, 08:45 AM
  #35
ItzFilyO
ItzFilyO's Avatar
Received 1,047 Likes on 662 Posts
I think they locked it down so that people can't sell unauthorized copies of the HDD.
Old 04-10-17, 10:05 AM
  #36
Im2bz2p345
Im2bz2p345's Avatar
If you wish to unlock the hard drive (for cloning), here are instructions: https://geekscrowd.wordpress.com/201...our-hard-disk/
This was the solution that someone posting with the exact same problem here: http://www.tomsguide.com/forum/id-18...ard-drive.html
Just passing along some information. I would be curious to see if there are any performance gains because of this. I know first hard the benefits of a SSD over a traditional HDD, although the bottleneck here might not be the I/O of a HD, but the Nav's processor as tejanp rightfully pointed out.
~ Im2bz2p345
Old 04-10-17, 10:13 AM
  #37
jtrue28
jtrue28's Avatar
So based on that website, we're thinking the password is "32 spaces"....for the Toshiba drive that OP has (and likely all of us).
I think the key takeaway point here is that doing this method may lockout the drive completely...which would then make it not work in the car. Proceed with caution.
Old 04-10-17, 10:30 AM
  #38
peasodos
peasodos's Avatar
I'm not brave enough to mess with a locked hard drive other than attempting to clone it with software. If the drive becomes unusable in the car, it's too expensive to replace from Lexus.
I'm hoping someone more technical/knowledgeable than me can use the information I posted to remove the drive and attempt to clone it.
Old 04-10-17, 10:37 AM
  #39
ItzFilyO
ItzFilyO's Avatar
The password is probably the VIN number.
Old 04-10-17, 10:50 AM
  #40
Dallasguy1
Dallasguy1's Avatar
Some users over here work with Lexus dealers I'm sure they can chime in if this is possible or not.
Old 04-10-17, 01:12 PM
  #41
e60bmw
e60bmw's Avatar
Very cool idea, I'm guessing you could probably just dd the drive from the source to destination if you mounted it in linux. I'm not sure what type of filesystem is used on this drive. I could probably figure out something but then again I'm not going to experiment with my personal drive. Perhaps there are some on ebay that could be purchased. I'm more interested in if someone could break into the ECU so some could develop a supercharger/turbo kits for our cars.
Old 04-10-17, 01:34 PM
  #42
jkeller
jkeller's Avatar
Or map navigation map fullscreen for 13.14 and 15's
TrevorTran (06-20-17)
Old 04-10-17, 05:25 PM
  #43
aachowhan
aachowhan's Avatar
A replacement cost 1500 dollars. Maybe I should set up a go fund me and then see if I can raise some money to get one and try cracking it. There has to be a way.
https://www.mylparts.com/oem-parts/l...bC12Ni1nYXM%3D
Old 04-10-17, 06:43 PM
  #44
jtrue28
jtrue28's Avatar
And that's with 20% off. Jesus Henry Christ III.
Old 04-10-17, 07:03 PM
  #45
peasodos
peasodos's Avatar
You can get the entire stereo/nav unit with hard drive from this wrecked Lexus for $275:
It also is for Mark Levinson sound system
Grade A Condition:
https://www.tlsautorecycling.com/sea...0h/291055.html
Quick Reply: Replace factory Nav Hard Drive with an SSD
