Vibration at 40mph and around 75mph
Solution:
Combination of bad alloys and stiff tires contributed to the vibration. returning back to stock OEMs with dunlops have dramatically improved vibrations
Have the rotors turned and I would go back to OEM pads. I would bet that you are feeling brake judder. I had this on a set of brembo's with full floating rotors and to was bad and took a long time to diagnose.
Do u remember hitting a pot hole, my front passenger was slight bent due to some pot hole action and I had this vibrating problem. Had to get the wheel redone and yes the vibration is gone.
I just changed to summer wheels and the vibrations are still there, no abnormal vibrations while braking from high speeds though. What are my chances that both my wheel sets are out of balance?
I don't hear a constant noise, its more of a oscillating noise that seems to happen with every rotation of the wheel. at low speeds at less than 45 mph i don't hear anything.
