Trunk Spoiler lifting
Old 05-02-17, 09:03 AM
MustangSal
MustangSal's Avatar
Default Trunk Spoiler lifting
Just noticed that there is an emerging gap between the spoiler and the trunk itself.
How are they attached? Bolted on? Anyone have theirs loosen? How do you get the inner skin tabs off?
Will post a pic later.
TIA.
Old 05-02-17, 11:04 AM
AJLex19
AJLex19's Avatar
Received 1,157 Likes on 854 Posts
TIA.
If the dealership did the install or if it was part of the F-Sport package, it should have been bolted/screwed-in with two bolts/screws. This means they would've drilled two holes into the trunk. If you see it lifting, maybe the areas where the tape from the spoiler is coming off slightly.
Old 05-02-17, 04:15 PM
shurik74
shurik74's Avatar
Correct, 2 bolts... also additional I believe 2 holes for plastic clips built into Fsport spoiler/lip making total of 4 holes in trunk... 2 bolts on each end & 2 plastic clips close to the middle of spoiler.
Base model GS has only 2 holes for bolts and rest is double tape.
Old 05-04-17, 02:50 PM
mrmahgoo
mrmahgoo's Avatar
Would it be difficult to install a trunk spoiler on a base model gs?
Old 05-04-17, 02:54 PM
shurik74
shurik74's Avatar
Super easy if you can make yourself to drill two holes yourself!!!! First time 15 years ago I was like "me drilling my car??? are you crazy???"
I just bought OEM painted one via ebay, seller has many colors available. Also, I purchased template for holes from different seller.
http://www.ebay.com/itm/322035459432...%3AMEBIDX%3AIT
Old 05-04-17, 02:57 PM
mrmahgoo
mrmahgoo's Avatar
thanks. I think it'll look better with one on
Old 05-04-17, 03:02 PM
mrmahgoo
mrmahgoo's Avatar
Thanks. I think it'll look better with one
Old 05-04-17, 04:40 PM
AJLex19
AJLex19's Avatar
I bought an OEM spoiler from sslexus (superstition springs Lexus on Amazon/eBay).
I did the install two years ago without drilling and used the supplied double sided tape and I added some 3M tape of my own as well. I had to Dremel off the bolts on the spoiler to get it to sit flush without drilling.
Just another way to do it without drilling...mine has been on with no issues to date.
Old 05-04-17, 04:47 PM
mrmahgoo
mrmahgoo's Avatar
thanks. Good to know
brahmabull
06-18-17 11:46 AM
moose66
01-31-14 11:11 PM
johnmilina
SC- 1st Gen (1992-2000)
10-24-12 08:18 AM
TFD99
07-20-12 06:54 PM
nonopr01
02-11-11 11:05 AM
Quick Reply: Trunk Spoiler lifting
